brake booster differences
Old Sep 17, 2011 | 02:21 PM
LatnKng's Avatar
Icon2 brake booster differences
Would a brake booster with ABS be different from one without?? I.E 92 prelude type S versus a 94 prelude type SI!!
Old Sep 19, 2011 | 07:05 AM
andoxviii's Avatar
Default Re: BRAKE BOOSTER DIFFERENCES
Are they different part numbers?
http://www.hondaautomotiveparts.com/
Old Sep 19, 2011 | 02:16 PM
Hawkze_2.3's Avatar
Yes, the boosters are are different. You may be able to adjust them to work with the opposing MCs, but I have not heard of anyone doing that.
Old Sep 19, 2011 | 06:43 PM
Apex1972's Avatar
and its NOT a TYPE S!!!!!! the Master cylinders are slightly different on the mounting surface. I forget exactly, but one has a small area notched out to prevent one from fitting onto the other.
Old Sep 28, 2011 | 07:01 AM
LatnKng's Avatar
yes i agree on the master cylinder part..one hole is bigger than the other...found that out after.
As for the booster itself the SI has a longer rod inside it which caused my front brakes to lock up completely after driving it for a mile or so after heating. I had to release the built up back pressure on the master cylinder itself to release the brakes. Finally i switched the booster for a 90 accord sedan non ABS..works great.
Old Sep 28, 2011 | 07:03 AM
LatnKng's Avatar
The reason i couldn't use my old one after i removed it was Bcus i used it as core charge for the ABS one..which i had no idea was ABS.
Old Sep 29, 2011 | 11:42 AM
Acidcrakker's Avatar
Default Re: brake booster differences
I have abs booster running a non abs car with no issues.
sonic47
Aug 18, 2009 10:33 AM
DRKSol
Sep 14, 2004 09:04 AM
DMF
15
Feb 1, 2003 04:02 PM
