93 lude headlight problem.. HELP
Old Oct 28, 2011 | 11:27 AM
SELF MADE's Avatar
Default 93 lude headlight problem.. HELP
so out of no where my headlights stopped working.. all other lights turn on with switch ( tails, bumpers, dash) but headlights wont. ive replaced relays, bulbs, checked fuses, grounds and replaced light switch and still nothing!! any help is appreciated im kinda stuck and out of ideas
thanks in advance
Old Oct 28, 2011 | 12:25 PM
snobordboy's Avatar
Moderator
Default Re: 93 lude headlight problem.. HELP
Both lights at once? That is a bit odd, but I would get out a multimeter, and start checking your wiring for power, and trace back until you find power. maybe you have a wire in the harness that got corroded or cut?
Old Oct 28, 2011 | 01:20 PM
SELF MADE's Avatar
Ya they both are out. Ok ya I will try that out hopefully I can figure it out soon thanks for the reply I appreciate it
Old Oct 28, 2011 | 05:40 PM
PABB4's Avatar
Low and high?
Old Oct 28, 2011 | 05:47 PM
Hidenplanvew's Avatar
hids? I think theres a fuse for left, right headlight?
Old Oct 28, 2011 | 06:30 PM
SELF MADE's Avatar
Both lows and highs. No hid's.. OEM headlights
Old Oct 29, 2011 | 05:13 AM
nus_dogg's Avatar
Did you use a multimeter to measure continuity at the bulb connectors to see if there's ground or power? I'm looking at the wiring diagram right now on All Data, and all I can think of is check your ground points and fuses.
Old Oct 29, 2011 | 08:07 AM
HeadlightBulbs's Avatar
It could be the harness needs to be replaced. As suggested above, use a multimeter to check for power at different places, starting from where you insert the headlight bulbs and working your way back.
DoubleEx
Apr 7, 2010 01:13 PM
mister.wong
Nov 1, 2009 09:05 AM
shauny2times
Jan 12, 2009 08:16 AM
Rhymenoceros
Apr 22, 2007 07:23 PM
JDM_d15b_eg8
Jun 25, 2006 02:16 PM
