Replacing the lower window trim
Old May 28, 2005 | 09:26 AM
AzCivic1.6's Avatar
Default Replacing the lower window trim
Tried searching and couldn't find anything.
So how do you remove that trim piece thats on the outer part of the door where your hand would rest if the window was down. basically at the base of the window.
here's a pic:
http://www.slhondaparts.com/br...=true
Old May 28, 2005 | 12:24 PM
AzCivic1.6's Avatar
does anyone know? i think you just pull on it til it pops out but i'm really not sure.
Old May 29, 2005 | 06:23 PM
AzCivic1.6's Avatar
bump!
Old May 29, 2005 | 06:37 PM
mxer518's Avatar
Default Re: (AzCivic1.6)
hey you just pull up at it very hard, try to get somthig under it to pry it up..... u will usally end up bending it and you will have to get another one....
Old May 30, 2005 | 06:06 PM
AzCivic1.6's Avatar
Default Re: (mxer518)
will any of the clips break off or anything? i'm replacing them so bending them is no biggie.
Old May 30, 2005 | 06:11 PM
mxer518's Avatar
ya i think like 2 broke on me....
Old May 31, 2005 | 07:01 PM
AzCivic1.6's Avatar
did anything inside the door break or was it just the pieces on the trim that broke? thanks!!!
Old Jun 2, 2005 | 07:27 PM
AzCivic1.6's Avatar
bump
Old Jun 3, 2005 | 08:05 AM
madcowdk's Avatar
Default Re: Replacing the lower window trim (AzCivic1.6)
The clips are pretty strong. I would lay some masking tape down to protect your paint and use a flat head to pry it up.
Old Jun 3, 2005 | 01:26 PM
PrettyLude's Avatar
Default Re: Replacing the lower window trim (madcowdk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcowdk &raquo;</TD></TR><TR><TD CLASS="quote">The clips are pretty strong. I would lay some masking tape down to protect your paint and use a flat head to pry it up. </TD></TR></TABLE>
Old Jun 6, 2005 | 06:06 PM
AzCivic1.6's Avatar
cool thanks!
Old Jun 6, 2005 | 08:19 PM
chitownrida's Avatar
DONT bend it. its really hard to get it back into shape once its bent
Old Jun 6, 2005 | 11:44 PM
vietluder2k1's Avatar
hes replacing it anyways, so its okay for him to bend it.
welfarepc
16
May 13, 2009 10:55 PM
ef9robert
Mar 14, 2006 08:44 AM
MxJones92
13
Jan 17, 2006 05:00 AM
NikoZai
Mar 8, 2005 11:00 AM
BigChris
Sep 25, 2003 03:05 PM
