97SH issue
Old May 30, 2005 | 06:55 PM
TypeSH03R6's Avatar
Default 97SH issue
hey guys...got a noob question..but a week ago..after gettin pulled over i tried to turn the car on and it wouldn't start..i tried again it started, but it would stall out rite away..then i put it in gear drive off a lil bit and it would move, BUT the engine sounds like **** and its shaking alot.. so i finally got the car to move but once i have the car either on Neutral or Idle the car would stall and i'd have to start the car up again. Any ideas???
Old May 30, 2005 | 08:08 PM
PrettyLude's Avatar
any cel?
Old May 31, 2005 | 05:58 AM
TypeSH03R6's Avatar
Default Re: (PrettyLude)
yea the cel light is on..the sound of the engine sounds like a lawn mower!! sucks ***
Old May 31, 2005 | 07:49 AM
RA062424's Avatar
Default Re: (TypeSH03R6)
Did you see if your spark plug wires are set right?
Old May 31, 2005 | 08:32 AM
speedracer9k's Avatar
sounds like a missfire to me, check to make sure your plugs are in the right way and are pushed in all the way. then check to see if your plugs are fouled.
Old May 31, 2005 | 09:26 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (speedracer9k)
Ignition recall?
Old Jun 5, 2005 | 09:44 AM
TypeSH03R6's Avatar
i got my car checked out...it looked like a bad spark plug..so went to go get new ones..but the car still sounds the same and still stalls on Idle.. any ideas?
Old Jun 5, 2005 | 04:33 PM
MTL514's Avatar
Maybe idle control, i once had a similar problem and it ended up being idle control. If it ends up being the tranny, let me know, I have a good deal on a sick tranny for SH or JDM Type-S
Old Jun 5, 2005 | 04:54 PM
vinuneuro's Avatar
Default Re: (MTL514)
well, did you pull the code from the cel to see why it was on?
Old Jun 5, 2005 | 05:23 PM
TypeSH03R6's Avatar
Default Re: (vinuneuro)
the code was P0122 ..bad TPS...but that was the only thing that was wrong with it..
Old Jun 6, 2005 | 05:33 PM
PrettyLude's Avatar
is the sensor itself bad, or does it need to be calibrated?
Trojan Man
Apr 28, 2009 05:53 PM
martyball619
Apr 27, 2008 11:58 AM
pvt_awol
Sep 15, 2007 09:35 AM
Mr.EM1
Dec 12, 2006 10:00 PM
schuetts
Dec 11, 2006 08:35 PM
