distributor
Old Aug 31, 2005 | 09:33 PM
gamblezhang
Guest
Posts: n/a
Default distributor
last time i change the seal in side the distributor...so i take it aparts....i put it back...do i need to set the timming? my timing is 15.(warm up already).....do i need to do something when i take it aparts? sorry for my bad english again.
Old Sep 1, 2005 | 09:52 AM
Rosko's Avatar
Default Re: distributor (gamblezhang)
If you took it all the way off then I would say yes you need to at least check the timing and adjust it if needed.
Old Sep 1, 2005 | 12:03 PM
IHateJDM's Avatar
Default Re: distributor (Rosko)
I would check it, but if you set it right in the middle, you won't be far enough off to cause problems if your motor is internally stock.
azzurribaggio
Jun 26, 2009 09:25 PM
madmortar
Jun 12, 2008 01:24 AM
eppoh
Jun 17, 2005 07:29 PM
H23ludedude
Feb 11, 2003 11:12 AM
