sleeving the engine?
Old Aug 31, 2005 | 11:15 AM
xrabb1t's Avatar
Default sleeving the engine?
wut exactly does this mean and how much does it cost to do ?
Old Aug 31, 2005 | 11:17 AM
Eddiebx's Avatar
u bore out the old sleeves, and pop new sleeves inplace, it can run anywhere from 500-1500 depending on what kind of sleeves you get
Old Aug 31, 2005 | 11:18 AM
xrabb1t's Avatar
cause i was told i need to do that and get new pistons for putting a turbo on my car
Old Aug 31, 2005 | 11:32 AM
xrabb1t's Avatar
is that right? is there diffrent kinds of sleeves u can buy ? like wat brands?
Old Aug 31, 2005 | 11:33 AM
DIRTYsouthBB6's Avatar
Golden Eagle makes them for the H22A4
Old Aug 31, 2005 | 11:40 AM
xrabb1t's Avatar
i have h23 the usdm one and right now all i have is intake, piping, exhaust, spark plug wires, and thats about it, i got used engine it only has about 25k miles on it though
Old Aug 31, 2005 | 11:46 AM
quadiv20's Avatar
Default Re: (xrabb1t)
What kind of turbo and how much boost do you plan to run on your set up?
-B
Old Aug 31, 2005 | 12:45 PM
draxxus07's Avatar
u dont HAVE to sleeve the motor to run turbo... if u want reliability and piece of mind and plan on boosting alot then yea you have to... you can run the motor on stock internals for as long as u keep the boost down and have good tuning... the consensus around here is no more than 8psi but ive seen someone on stock internals pushing 11psi but with boat loads of tuning
Old Sep 1, 2005 | 10:10 AM
xrabb1t's Avatar
im not sure what kind of turbo's i want yet but yea i was only planning to do about 8 psi, and with the tuning what kind of tuning and turbo shuld i get done?
Old Sep 1, 2005 | 10:54 AM
DMF's Avatar
DMF
My block is sleeved by Golden Eagle (well being e-sleeved right now) fing money pit! Also expect your block to be there for at least 3 weeks. I believe the first itme you sleeve a block with them it is right about $1000. Re-sleaving wont cost quite as much (thank god).
You are only going to have a limited life on a H22 without sleeving it, especially with a decent amount of boost. The stock cylinder walls have a coating on them and they don't last as long as a the cylinder walls in other Honda engines.
I'm a big supporter of doing it right the first time. Youa re just going to want more boost and more power. You shoudl just make it reliable right from the start.
Old Sep 1, 2005 | 05:05 PM
xrabb1t's Avatar
does golden eagle sleeve blocks for h23's also? and where do i go to get it done?
Old Sep 1, 2005 | 09:44 PM
DMF's Avatar
DMF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrabb1t &raquo;</TD></TR><TR><TD CLASS="quote">does golden eagle sleeve blocks for h23's also? and where do i go to get it done?</TD></TR></TABLE>
I believe they do.
http://www.goldeneaglemfg.com
909-592-4311
Is it a bad thing when I only had to look at the phone book in my cell phone to get that number?!?!
Old Sep 1, 2005 | 11:40 PM
PrecisionH23a's Avatar
Default Re: (DMF)
I have a set of Darton H series sleeves for sale.
https://honda-tech.com/zerothread?id=1334471
mykulangot92
Dec 3, 2010 06:00 PM
slammedobd1teg
Apr 16, 2009 05:38 AM
JayIntegra
Sep 13, 2007 09:02 PM
you69
Feb 13, 2003 08:17 AM
