steering wheel
Hey all,
Ok I have this little problem, when at higher speeds my steering shakes quite a bit and when making left turns it's more harder than turning right. I just recently replaced my drive shafts and my new shocks are on the way. What can be causing this shaking in my steering wheel. Oh and by the way I took off my ps belt more than a year ago.
maybe it needs a front end elignment, on my lude when i braked it would shake a lot and i found out i had a cracked/broken in half brake pad. I did both and like u i dont have the power steering either and mine shakes a little bit but i think the front strut bar from tanabe that i put on helped alot with the shaking from the brake pad (and yes i replaced it).
If it's a vibration only at higher speed, then it's your tire being out of balance.
The harder turning in one direction to another is probably improper air pressure.
R-Lug
25
Dec 9, 2005 04:27 PM
AutoXMan
Nov 22, 2005 10:04 PM
Do_Ster
Jul 27, 2004 10:38 PM
