need help fast with a simple electrical question
Old May 3, 2006 | 06:31 PM
DIRTYsouthBB6's Avatar
Default need help fast with a simple electrical question
The power wire from my fuse box ( under the hood ) shorted out and the tip of it melted... I looked in the fuse box and no fuses look to be blown out. I was able to grab the wire off of the ground before it got dangerous... should I just reconnect the wire and drive, or is there now something that is probably messed up that I need to fix or some kind of fuse that I need to replace?
Old May 3, 2006 | 06:47 PM
M2B4's Avatar
Default Re: need help fast with a simple electrical question (DIRTYsouthBB6)
the (+) wire from battery? that what your talking about? what part melted? how did this happen? grab a multimeter a test the wires if you run into any problems. if no fuses are blown then just replace the wire and you be ok.
Old May 3, 2006 | 07:42 PM
The 100-ampere fuse under the fuse box in the engine bay didn't blow for some reason. I just sliced-off the little bit of crispy wire at the end and reconnected it, and evrything seems fine now. My projector retrofit is complete!!!!
I Love My 4 door
Dec 19, 2010 04:05 PM
emooheo
Audio / Security / Video
11
Oct 6, 2010 05:53 AM
edwinbaby
Sep 7, 2010 02:08 PM
andyhoiho
May 29, 2004 07:58 AM
95gsr
Sep 18, 2001 09:25 AM
