what size are h22 injetors
Re: what size are h22 injetors (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx »</TD></TR><TR><TD CLASS="quote">is there a different between h22 and h23 injectors</TD></TR></TABLE>
yeah h23s are smaller CC's i can't remember, its like 240 or somewhere around there
moderator emeritus
Re: (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx »</TD></TR><TR><TD CLASS="quote">375-450</TD></TR></TABLE>
i'd go 700cc+
but im an all motor guy...........its better to have bigger injectors than needed
i'd go 700cc+
Re: (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx »</TD></TR><TR><TD CLASS="quote">I am think i am going to get the the 750 cc</TD></TR></TABLE>
Great
However.
In order to support 450 crank HP, you'll need to have your fuel pressure at ~70psi.
*This is assuming your injector duty cycle won't exceed 80%
If you want to keep the stock fuel pressure ~44psi, you'll need almost 1000cc injectors. If you get an adjustable FPR, up the fuel pressure to 50psi, you can do ~850cc injectors.
__________________________________________________ _____
For 375 crank hp
At 50psi - 750 will be great
For stock fuel pressure (44-43psi) you'll need 780cc injectors - i think precision makes 780cc.
Remember - this is all at 80% duty cycle. You really don't want exceed that - if you do, do it under rare conditions.
Hope that helps any.
Great
However.
For 375 crank hp
on this subject for aftermarket injectors i see that RC next size up for peak and hold injectors is 550c ? kinda over the top for a NA car... anyone know of any inbetweens
Re: what size are h22 injetors (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">OBDI = peak and hold 345cc
OBDII = saturated 290cc</TD></TR></TABLE>
bingo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">
yeah h23s are smaller CC's i can't remember, its like 240 or somewhere around there</TD></TR></TABLE>
h23 = 240cc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx »</TD></TR><TR><TD CLASS="quote">i want to run more boost like 12-15 psi what size injectors</TD></TR></TABLE>
for 12-15 psi 750+ should be good...
bingo
h23 = 240cc
Re: what size are h22 injetors (prelittlelude)
try to get as close as you can with some room for error. Example, if you calculated you'll need 550s, look for some 620s or so. The bigger you go, the harder it is to make it idle, because a big injector can only open and close so fast....it will run richer and richer at idle as the injector gets bigger and bigger. For another example, in the RX7 world, we use 850 in the primaries and secondaries for boost up tune cars, then 550's and 1600s secondaries. Otherwise, anything bigger than 850 primaries makes the car run too rich at idle and starets to foul out plugs
Re: (94preludeguy)
i think i am going to use the stock ecu and the h23 intake manifold to break the motor or i could use my aem ems with the wideband o2
Re: (94preludeguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94preludeguy »</TD></TR><TR><TD CLASS="quote">Up to 10psi DSM 450cc injectors should be fine but anything past that get 550+</TD></TR></TABLE>
if properly tuned you will be to close to max dutry cycle at 10psi with 450cc,
with my tune at 10pis on 550cc i am approching 85% duty cycle at redline, and on 450cc that would be pretty close to 95% duty cycle.
also before for someone brings up just raise your fuel presure, you need to know that when you raise your fuel presure it puts more of a strain on the injector to open and close. and at higher rpms with a smaller injector and higher fuel press it becomes harder for the injector to keep up. you can end up over loading and buring an injector. just go with a larger injector and a fuel presure of no more than 50 psi max
as far a motor break in goes, just make sure to match the ecu with the injector, h23 = 240cc and you definatly don't want to run overly rich and wash the cylidners down and keep the rings from seating.
