Which one?
Old May 1, 2006 | 03:14 PM
korney's Avatar
Default Which one?
Alright guys, I have spend numerous hours, days, even weeks, maybe a month researching and debating which head to swap. Ok here is the scoop, I have the Prelude S model, and I want to swap out the head for something different, and I am down to these two, F22b1 or h23a1 head. I am going turbo in the soon future. Which one do you think that I should do? which one is better for the turbo?
FYI, I know how to do both swaps, with help from my brother in law
In short, which one whould you do, and why...?
thanks!
Old May 1, 2006 | 05:26 PM
korney's Avatar
Default Re: Which one? (korney)
alright anyone else?
Old May 1, 2006 | 07:54 PM
i_kick_turtles's Avatar
It's not even a contest. With the h23, you will have better breathing, better aftermarket, and the added tuneability of DOHC. SOHC VTEC
Old May 2, 2006 | 08:29 AM
korney's Avatar
Default Re: Which one? (I R Tylor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I R Tylor &raquo;</TD></TR><TR><TD CLASS="quote">It's not even a contest. With the h23, you will have better breathing, better aftermarket, and the added tuneability of DOHC. SOHC VTEC </TD></TR></TABLE>
Yes I know that what you said is true, but, the idea of having vtec is pretty cool, just as in the Accords, my buddy's friend has a 94 sohc vtec fully build, and it pulls pretty hard, but all I am asking, which one is better for turbo.
Thanks I R tylor for the feedback!
Old May 2, 2006 | 04:24 PM
helicopter201's Avatar
better aftermarket selection of turbo cams for one thing with the h23a. did i hear someone say crower? and rarity beyond the wimpy f22b. h23a FTW
DOHC is more tunable anyway since you can tune both intake AND exhaust cams seperately...
Old May 2, 2006 | 04:34 PM
flipwhip's Avatar
Default Re: Which one? (helicopter201)
h23 FTW!!
Old May 3, 2006 | 12:16 PM
korney's Avatar
Default Re: Which one? (flipwhip)
alright you guys, thanks for the information. It seems to be like h23 head swap for the win!!! BTW I have a 96, so which means OBD 2, and, well since I am going for the DOHC swap, it means I got to get the h23 ecu, should I just go ahead and do the obd 1 conversion? or get an obd2 ecu. FYI I don't know much about ecu at all, any help will do. thanks!
Old May 3, 2006 | 01:24 PM
korney's Avatar
ok, I just need to know if I should do the obd 1 conversion, cause I have obd2? I want to know cause I'm going turbo thanks...
Old May 3, 2006 | 06:41 PM
john d
Guest
Posts: n/a
Team Thunder Catz
Old May 3, 2006 | 06:54 PM
If you use the h23 ecu, you will run a little rich because the h23 has higher compression. Since you are going to go turbo, it would be a good idea to buy a conversion harness and chip a p06. You will save a few bucks and some time in the long run.
Old May 3, 2006 | 10:46 PM
and if money is not a problem:
p72 + hondata s300 FTW
Old May 4, 2006 | 04:38 AM
korney's Avatar
Default Re: Which one? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">Team Thunder Catz </TD></TR></TABLE>
you bet cha!
Old May 4, 2006 | 04:42 AM
korney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helicopter201 &raquo;</TD></TR><TR><TD CLASS="quote">and if money is not a problem:
p72 + hondata s300 FTW </TD></TR></TABLE>
yeah I plan on not going cheap for this setup...
Old May 4, 2006 | 09:29 AM
Hawkze_2.3's Avatar
+1 for H23 head swap and OBD1 conversion.
Iron sleeved F22 block + H23 head + turbo setup = kickass.
Old May 4, 2006 | 10:23 AM
GtechPro's Avatar
Might as well do an H23 swap then... Or is that not a reasonable option for you?
Old May 4, 2006 | 12:33 PM
korney's Avatar
Default Re: (GtechPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro &raquo;</TD></TR><TR><TD CLASS="quote">Might as well do an H23 swap then... Or is that not a reasonable option for you? </TD></TR></TABLE>
I'm going turbo, so the iron sleeves in my f22 will do, thanks for the opinion.
Old May 4, 2006 | 12:43 PM
korney's Avatar
Default Re: (korney)
ok, I just got reading all about ecu blah blah....well...my question is that, should I just run a p14 + hondata? turbo build won't happen atleast until next spring. so what should I run for ecu? p14+hondata? I'm pretty sure that I'm going to run rich cause the h23 has a higher compression than the f22.
Old May 4, 2006 | 12:49 PM
Fat Gurls Rock's Avatar
humm... i waz thinkin H23 bl0ck with the H22 head' but watever make u have =P
Old May 4, 2006 | 02:24 PM
Default Re: (dj bOysMiTh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj bOysMiTh &raquo;</TD></TR><TR><TD CLASS="quote">humm... i waz thinkin H23 bl0ck with the H22 head' but watever make u have =P</TD></TR></TABLE>
He's going turbo, the high compression of the h series is no good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korney &raquo;</TD></TR><TR><TD CLASS="quote">ok, I just got reading all about ecu blah blah....well...my question is that, should I just run a p14 + hondata? turbo build won't happen atleast until next spring. so what should I run for ecu? p14+hondata? I'm pretty sure that I'm going to run rich cause the h23 has a higher compression than the f22. </TD></TR></TABLE>
I don't believe you can chip a p14, but I'm not familiar with hondata. I suggested a P06 because they can be had for cheaper than ecu's that work with VTEC.
Old May 4, 2006 | 03:46 PM
korney's Avatar
Default Re: (I R Tylor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I R Tylor &raquo;</TD></TR><TR><TD CLASS="quote">I don't believe you can chip a p14, but I'm not familiar with hondata. I suggested a P06 because they can be had for cheaper than ecu's that work with VTEC. </TD></TR></TABLE>
hmm...you want me to use a civic ecu? ok, I guess I really dont know anything about ecu's as I thought.
Old May 4, 2006 | 03:49 PM
korney's Avatar
ok well, what should I use, what is the best, what is possible? hmm....can't I just use a h23 ecu with hondata? and also is hondata turbo programable?
661rex89si
Feb 6, 2009 09:56 PM
tn265
Jul 21, 2006 05:46 PM
90AccordSi
May 31, 2005 02:27 PM
blackhash
Apr 15, 2004 10:44 AM
