Which ECU?
Old May 7, 2009 | 05:53 PM
Enzo15's Avatar
Default Which ECU?
Hi, Im kinda new to this forum but Id like to know if any of these ECU's swap directly over to a 95 Vtec Prelude? I plan on getting the Hondata chip and these are the ECU's they have for their kits: P72,P28,P30,P61,P08J,P30J,P72J Which would be a direct swap for the H22A Vtec motor?
Old May 7, 2009 | 06:16 PM
coryfenton's Avatar
Default Re: Which ECU?
https://honda-tech.com/forums/honda-prelude-4/definitive-prelude-ecu-choice-hondata-info-post-567799/
Research is key.
Old May 7, 2009 | 06:32 PM
Enzo15's Avatar
lol thanks, I had read that, but hadnt understood it all that well. So Im guessing all of those just drop right in then?
Old May 7, 2009 | 06:36 PM
Kronn 98SH's Avatar
Originally Posted by that ECU thread
P72 - The GSR ecu. This ECU does control the IAB's and also has knock sensor capability, but is more expensive than the P28 ECU. Technically this is the best ECU to use, because it has all of the features, but usually these ECU's are overpriced. Knock sensor capability is mostly useless, but if you're running an N/A motor the IAB control might be something you want.
I'm not sure how you don't understand that.
Old May 7, 2009 | 06:47 PM
Enzo15's Avatar
lol thanks, like i said i didnt get it when i read it the first time last night... I was half asleep lol. But i re read it again and I think i got it, thanks : )
Old May 7, 2009 | 08:42 PM
coryfenton's Avatar
they should plug in, i think they 95 is still obd1.. not sure tho. they should all plug in but some may not run as good as others..
Old May 7, 2009 | 09:04 PM
gooselude's Avatar
just a bit of knowledge i've picked up from local 4th gen prelude owners. i had the same question about which ecu to use and all have told me that through their experience the p28 worked really well for what they were looking for.
and to answer coryfeyton: yes the prelude ecu was OBD1 until the 5th gen came out in 97. but the general rule (not always of course) is that most cars older than 96 are OBD1.
Last edited by gooselude; May 7, 2009 at 09:05 PM. Reason: sorry coryfeNton not feyton my bad/
Old May 8, 2009 | 06:17 AM
Enzo15's Avatar
ok kool thanks guys. I plan on goin for a high hp/tq build so i guess either the P28, or P72 would be good. I also plan on putting in the Hondata system so hopefully this will all work out. Thanks : )
Old May 8, 2009 | 09:46 AM
hondaZvic's Avatar
p28 is what most h22 owners use (that i've dealt with anyway)
the only issue with it is like stated before, no IAB control. But, IAB's can be hooked up by other means if necessary.. or if u run an aftermarket I.M. then IABs are no longer an issue.
Old May 8, 2009 | 01:50 PM
Enzo15's Avatar
O ok, kool, Ya I plan on running a different IM so I guess that would work if I can get it cheaper lol thanks. : )
Old May 8, 2009 | 11:33 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
I got a P72 with an H22 program already installed for the cheap!!! PM me.
Alex Haynes
Jul 17, 2018 08:34 PM
jeck_bar2
Mar 11, 2009 09:12 AM
lyttleviet
Sep 26, 2007 10:22 AM
aaron14229
Dec 17, 2001 08:59 AM
DSGB.
Oct 19, 2001 12:06 PM
