Engine wont start
Old Apr 26, 2009 | 04:59 PM
amalby's Avatar
Default Engine wont start
I just finish rebuilding my H23a1 and it fired right up. I timed it and this thing sounded amazing. during the process of pulling my engine out i forgot to unhook the o2 sensor from the acutally intake main support and it ripped all the wiring out. no problem ill just put the back in. so I spent some time on here and I think I found the way it was suppose to go on. so I plug it in and go to fire it up and it just sits there and cranks. so I unplug the o2 and try it again and still it just cranks. even though it was working just fine 20 mintues ago. I check the dash and the CEL light is on when the key is in the on postion. so I grab a paper clip and put it in the service hole. turn the key back on and no flashes. The only flash there is is the SRS flashing.
I checked for spark, none. Fuel is getting there but when I pulled the spark plugs after cranking it for a good 10 seconds, there is barely and smell of gas.
So now im stuck. Did I wire up the O2 sensor wrong and send a singal back to my ECU and fry is or should I be looking for something else?
literly nothing happen after I timed it besides hooking up the o2. so this has me going through a loop.
Thank,
A-Dub
Old Apr 26, 2009 | 11:15 PM
amalby's Avatar
Default Re: Engine wont start
Just got done working on it some more...after scratching my head for a while im still in the same boat.
I do need to correct my self though, the fuel pump never kicks on for the 2 second prime. so I am not even getting fuel. And still no spark. not even from the coil.
it has to be something simple that I havent thought of.
any ideas???
Old Apr 27, 2009 | 02:28 PM
amalby's Avatar
When I have the key on I have power at the dizzy and coil. no spark when I turn it over. I checked all the engine bay fusses, there ok. I dont hear a click when I turn on the car to start so I pulled the main relay out. swaped it with my 92 lude and still no click. with that the fuel pump still wont kick on.
the CEL is still on and wont show me any codes when I use the service pin.
Old Apr 27, 2009 | 04:59 PM
jbparrothd21's Avatar
Did you check all of your grounds?
Old Apr 27, 2009 | 10:06 PM
amalby's Avatar
after an hour or so using the volt meter and the helms service manual I found the problem. I was checking if there was voltage at the main relay and i didnt. so i checked teh number 4 fuse under the dash and what do you know the fuse was blow.
This happen becsuse my when i rewired my o2 sensor I wired it wrong and it blew the fuse.
I hope this can some how help someone else
Old Apr 28, 2009 | 05:38 PM
Glad to hear it was a simple fix...and thanks for closing out the thread for all those who will stumble across this a few years down the line.
Nate Smith
Honda CR-V & Element
Oct 9, 2017 05:35 AM
xxzombierot
Mar 10, 2013 09:53 PM
egtony
Jul 19, 2009 10:18 AM
itrhopeful
29
Jan 16, 2005 03:54 PM
