??Auto or man. Block??
Old May 1, 2009 | 08:47 AM
9WON4's Avatar
Icon2 ??Auto or man. Block??
Hey guys,
sorry if this has been covered checked all the FAQ's couldn't find anything.
Question - How do I determine If I have an Auto block or a manual block??
is their any indicating number on the engine code, or is there anything that could help me figure this out??
thanks for the help
Old May 1, 2009 | 09:33 AM
9WON4's Avatar
Default Re: ??Auto or man. Block??
other then measuring the flywheel bolt recesses in the crank??
Old May 1, 2009 | 10:26 AM
Enzo15's Avatar
I could be wrong, but they are interchangable with the transmissions/blocks. I believe the main difference is the use of a flexplate instead of a flywheel. Someone with more knowledge please step in and correct me if I am wrong.
Old May 1, 2009 | 11:24 AM
vinuneuro's Avatar
Enzo15 is spot on.
Old May 1, 2009 | 12:38 PM
Enzo15's Avatar
Sweet lol
Old Oct 19, 2010 | 11:50 AM
9WON4's Avatar
I don't know if it's the same for all blocks but on the H22 the recesses for the flywheel bolts are a different length ;/
Old Oct 19, 2010 | 04:54 PM
minilogoguy18's Avatar
The only H22 with a different block is one that came in a 5th gen Type SH.
Old Oct 21, 2010 | 07:30 AM
TurboBB2's Avatar
How is it different?
Any H-series engine and transmission can bolt up together and work, being auto or manual has nothing to do with the block its all in the tranny (of course switching your car from manual/auto or auto/manual u'll need a few other things). You can even bolt f-series trannys on h blocks and vise versa. If you get an H2b kit you can mount up a b-series tranny if u really want to.
Right now i have a 2000 SH swap in my 92 with an H23 tranny from a 93.
Old Oct 21, 2010 | 07:58 AM
Kronn 98SH's Avatar
The ATTS blocks are different in several ways. ^ You most likely don't have one.
As for determining which block you have, see if the VIN is still on the back of the motor. That will tell you EVERYTHING.
Old Oct 21, 2010 | 09:00 AM
serjey15's Avatar
Dude, Many times when You guy JDM H22 engines they have auto transmission. You can still put manual transmission on them. Also How people put h22 transmission in accord with auto trannys. Blocks are not made for a certain tranny, at least h22's arent
Old Nov 30, 2010 | 01:47 PM
9WON4's Avatar
Aside from the obvious diff. in the SH block's, as I said there are slight differences in the Automatic vs. Manual/ H & F Series crankshafts:
"Honda has provided manual and automatic engine crankshafts with varying machined bolt depths for the flywheels."
^^^Quoted from someone who has done significant R&D on H22 blocks/crankshafts.
When running an H2B kit this can create a large issue as the "custom" flywheel bolts are susceptible to "walking" out of the AUTO crankshafts.
and PS....the cam profiles are also different in some (maybe all) of the Auto and Man blocks. Your comment of the only difference is in the Trans. is incorrect.
Old Nov 30, 2010 | 03:53 PM
mafia's Avatar
How big of a difference you talking? I have A 5th GEN auto block and A SH block next to each other... i can check what you want me too...
Ohh, and I have a Non SH block too from 4th Gen that came off a manual.
Old Dec 1, 2010 | 06:39 AM
9WON4's Avatar
Already had it checked I don't recall the difference it was negligible, yet enough to create an issue. I had Seth from QSD mic out the difference. He was very helpful when it was determined this could create the issue.
Thank you for offering assistance though!!
crix180
Dec 30, 2013 12:13 PM
girliehonda
Jun 4, 2007 07:14 AM
Phat8186
Aug 26, 2005 01:45 PM
khoalie
Dec 23, 2002 01:54 PM
civicmatt
Nov 18, 2002 07:35 AM
