Interior clock issue
Old Apr 24, 2009 | 07:03 PM
crxsleeper210's Avatar
Default Interior clock issue
ok ever since i bought my lude in november the clock has been acting weird......if i set the clock to the right time it will work for a day or so then after its been parked overnight, in the morning it will be set at a totally different time then what it should be at...also when i turn the **** to the right to change the minutes, if i hold the **** the minutes keep going up and doesnt stop until i turn off the car....any suggestions on what it could be? a new clock or **** maybe?? or is it something else...any help is appreciated...i hope i explained the prbolem clearly
Old Apr 24, 2009 | 08:08 PM
h23prelude's Avatar
Default Re: Interior clock issue
sounds like a clock problem, but check the power and grounds to the clock inputs first.
i'd go fetch one from a junkyard and try that one and see if it works.
Old Apr 24, 2009 | 08:37 PM
h23prelude's Avatar
i was bored, so i looked up the wires on alldata-
hot at all times - white/yellow wire
ign switch power - yellow
ground wire - black
theres 5 wires going to the "time set switch" aka the ****
check both fuses 43 and 13 they both feed the clock power
good luck
Old Apr 25, 2009 | 06:33 AM
1GPlusSH's Avatar
it's a ghost
Old Apr 27, 2009 | 04:56 PM
aasaa666's Avatar
make sure you dont have an electrical issue. If it isnt then it must be something wrong with the clock. We had a customer that had the same situation. Most of the time the clock will last as long as your seat belt retractors. This indeed is super rare.
Old Apr 27, 2009 | 08:49 PM
Kronn 98SH's Avatar
If you aren't having to reprogram your preset radio stations, then it's most likely just a bad clock.
Old Apr 28, 2009 | 03:53 AM
SnlpeR's Avatar
mines worse
my hour number scrolls upward pretty quickly
minutes are fine
i go through 24 hours in like 10 seconds
haha
Old Apr 28, 2009 | 08:07 AM
maverick32's Avatar
^^^^same here man...my younger sister calls my lude the back to the future car because of that...lol..then we laugh and smoke some more to get a bigger trip. its INTENSE!!!!!!!!
Old Apr 28, 2009 | 09:19 AM
no1knows908's Avatar
It's a very common problem on most 4th gens. Mine does it every now and then on hot days.
footstinker
Jul 7, 2010 10:58 AM
OMG THE GOGGLES
May 24, 2006 10:01 AM
OMG THE GOGGLES
May 23, 2006 06:32 PM
KrispyKreme
Audio / Security / Video
12
Mar 17, 2005 01:13 PM
blitz-integra
May 20, 2003 09:50 AM
