Broken wheel studs
Old May 11, 2009 | 07:26 AM
MJT805's Avatar
Icon2 Broken wheel studs
my prelude is a 93 and I'm not sure how I should replace 2 wheel studs. I really don't want to press the hub off and have to buy a new bearing but I don't see anyway around it. does anyne have experience witht his?
Old May 11, 2009 | 07:35 AM
Hawkze_2.3's Avatar
Default Re: Broken wheel studs
No pressing needed
Are they front or rear studs? Both can be hammered out and pulled back in with nuts, but the fronts have less space to work with.
Old May 11, 2009 | 10:54 AM
MJT805's Avatar
its the front. It doesnt look like theres enough room for a new one to go back in.
Old May 11, 2009 | 06:15 PM
Hawkze_2.3's Avatar
It is definitely possible, but you may have to grind a bit from the front of the knuckle. I have installed extended studs in the front and it just took some grinding, should be much less for a stock length stud.
It's a lot easier than the alternative
Old May 13, 2009 | 08:54 AM
jasoncmps@gmail.com's Avatar
i'ma try that. i dont want to spend the extra time and money. thanks!
Old May 13, 2009 | 04:09 PM
thePreludeMan's Avatar
New User
just curious...what symptoms are you noticing that are making you want to replace them?? is it a "clicking noise" up there? think i will soon be doing the same thing on the nissan family car.
Old May 13, 2009 | 04:56 PM
MJT805's Avatar
no symptoms. i was missing 1 since i had bought the car and when i went to take the wheel off 1 other was seized on there so i broke that one too. so i only have 2 outa 4 now and since i'm swapping motors this is a good time to get it done.
Old May 13, 2009 | 05:28 PM
Hawkze_2.3's Avatar
I bet people are tired of seeing my post this picture by now, but here is the area I had to grind to install the extended studs if it helps:
You won't have to do near as much for normal studs. Those rotary tool attachments that are a cylinder shape or sandpaper work great
Old May 14, 2009 | 07:16 AM
MJT805's Avatar
nice. i used a cut-off wheel to knotch in a little space.
Old May 23, 2009 | 02:27 PM
EE2bitsk's Avatar
thats the cheapest shittiest way to do it.
i'd just save the money and get it done rite.
Old May 23, 2009 | 02:35 PM
Hawkze_2.3's Avatar
Yes, it is the cheapest way. It's called making cost & time-effective decisions.
Please do explain how this is the 'shittiest' way to do and what is the 'rite' way. Taking all your suspension apart so you can put the hub in a press? No need for that.....
Old May 24, 2009 | 06:10 AM
lrayford's Avatar
im down with Hawkze, i wish i could have done that when i needed mine replaced, wish i had it right now, makes it nice and simple to pop in new studs
Old May 24, 2009 | 12:33 PM
EE2bitsk's Avatar
yeah actually that is the rite way.
you think when you sell your car, if you ever do, someone is gonna be stoked to see that ****?
its just lazy and half assed honestly. do it rite or dont do it at all.
just my 2 cents..
Old May 24, 2009 | 01:17 PM
Hawkze_2.3's Avatar
just my 2 cents..
LOL!, I will never be selling my Prelude. Even so, the integrity of the knuckle/spindle/whatever-you-like-to-call-it is not compromised in any way. I will drive with it like this for years from now as I have already been for years with absolutely no problems.
'Rite' is not a word, but certainly there is nothing wrong with adding your 2 cents
Old May 25, 2009 | 10:04 AM
EE2bitsk's Avatar
if it doesnt mess it up iguess its whatever.
and lets not get into a perfect punctuation/grammar war here.
rite = right
Old May 25, 2009 | 10:23 AM
meanshyguy's Avatar
I'd rather do it like hawkze said, saves time and money.
Old May 26, 2009 | 07:55 AM
EE2bitsk's Avatar
of course you would.
Old Jan 11, 2010 | 09:31 AM
4G92's Avatar
pix of the front hawkze. i plan on keeping my lude 4ever too!
Old Jan 11, 2010 | 10:24 AM
starbai's Avatar
a little grinding definitly did the trick... very simple to get them in/out after that.
Old Jan 11, 2010 | 12:14 PM
pheurton-skeurto's Avatar
ill take pics of both of my front knuckles on my 5th gen when i get home. they look just like Hawkze's. saved me roughly $200/side...$400 total.
Old Jan 11, 2010 | 01:03 PM
4G92's Avatar
thx
Old Jan 11, 2010 | 01:10 PM
Hawkze_2.3's Avatar
Pics of the front of the whole car or the knuckle? That pic is the front knuckle FYI....
Old Jan 11, 2010 | 01:17 PM
minilogoguy18's Avatar
Couldn't you just rotate the wheel to avoid grinding?
Old Jan 11, 2010 | 01:24 PM
Hawkze_2.3's Avatar
No, there's not a spot that has enough space for a stud to come through
Old Jan 11, 2010 | 03:31 PM
4G92's Avatar
ill be damned sure is! totally missed that. running on 18 of being awake...Im all for cost effective time saving work but grinding on the knuckle really urks me :/ How do you know the grinding of the knuckle does not affect it?
