370!!?!?!?
Old Oct 27, 2004 | 12:25 PM
esca's Avatar
Default 370!!?!?!?
the guy at wheel works.. told me for a replace ment of an axle and jv joints for both sides.. (driver / passenger front) would come to be 370 bucks...
form wahwt i hear.. axles and joints come to like 80 bucks.. so hes charging me like 200 bucks for labor? is this a good deal?
after seeing those numbers.. it kinda makes me think that i should try and tackle this myself.. but i dont really have any experience with axles and joints.. =p
Old Oct 27, 2004 | 12:28 PM
granteeton's Avatar
rebuilding axles isn't cheap or easy. but if that's for both, it's good. if it's just for one, he's charging double what he should.
Old Oct 27, 2004 | 12:32 PM
98TypeSH's Avatar
Default Re: (granteeton)
you can get an OEM SH axle for 220 bucks brand new. Is that 370 for both sides or just one. if thats just one go buy a reman or OEM one cheaper but hes gonna tag you for labor.
Old Oct 27, 2004 | 12:34 PM
AndyD's Avatar
Default Re: 370!!?!?!? (esca)
That sounds about right.
I replaced mine (when I did my swap). It's not as hard as Imagined. The hardest part if breaking lose the castle nut on the wheel hub (Air-tools makes this part VERY easy). Then you need to loosen your shocks where they mount to the control arm.
I will change them myself next time they need replacement.
bad-monkey's Avatar
the labor is relatively easy. do it yourself!
Old Oct 27, 2004 | 03:37 PM
esca's Avatar
Default Re: (bad-monkey)
bleah.. ihate wallet rapes.. yeah its for both sides.. but im thinking about having one side done.. but i heard plenty of horror stories that when one side is fixed.. the other side will break.. its like buying a pair of shoes.. you dont buy one new shoe when you need it.. you buy a pair..
Old Oct 27, 2004 | 03:40 PM
Revi's Avatar
Default Re: (esca)
I had my drivers side axle replaced with out the passenger one touched. And ive had no problems. What you hear is Import Myths.
Change the foker yourself, save some cash, gain some experience
Old Oct 27, 2004 | 03:45 PM
esca's Avatar
Default Re: (Revi-Ra)
mess up blow up car.. daily driver gone..
and do i need specific axles like.. ones for a jdm h22.. because when i was checking prices onlinei they had different likes like h23 and h22 and f22...
if i had a swap.. from f22 -> h22 should i be getting the h22 axles?
sounds stupid but i need confimation
Modified by esca at 8:30 PM 10/27/2004
brians356
24
Oct 16, 2015 12:55 AM
90Rexx
12
Jul 26, 2009 02:57 PM
lude27
Mar 4, 2008 05:23 AM
G1 TEGGY
Aug 17, 2004 04:34 PM
phatrick2332
Jul 27, 2004 08:51 AM
