nitrous???
Old Feb 8, 2005 | 07:39 AM
crxh22a4's Avatar
Default nitrous???
How much can you sqeeze on a h22 with some mods?
h22 crx
12.86@106.5mph
Old Feb 8, 2005 | 09:06 AM
chrisgags13's Avatar
Default Re: nitrous??? (crxh22a4)
what do you mean? how much nitrous you can put in a mostly stock engine? if so, i wouldn't go more than a 75 shot. but that **** is no cool. eventually with a stock engine, you'll have damaged pistons valves and eat through the valve seals quicker.
Old Feb 9, 2005 | 07:31 AM
crxh22a4's Avatar
Default Re: nitrous??? (chrisgags13)
thats what i herd the ****** rings get bad really fast!
h22 crx
12.86@106.5
Old Feb 9, 2005 | 10:26 AM
street_ruler's Avatar
no they dont, i have squeezed for a year now and i have no problems, i shoot 65 shot on a stock...STOCK b21a1 with 173XXX miles on the ODO...that tells ywa somthing, compression is good, no oil comsumption what so ever...what can i say
Old Feb 9, 2005 | 05:24 PM
Default Re: nitrous??? (street_ruler)
well you might be a special case...or you have only been using it for a year
get back to me in a few years when your pistons are f'd up and I'll bake you a cake that says I told you so....
Old Feb 9, 2005 | 07:17 PM
crxh22a4's Avatar
Well my crx is not my daily driver, but do you guys recommened any thing before the 75 shot....o ya its a wet shot!
h22 crx
12.86@106.5mph
Old Feb 9, 2005 | 07:53 PM
Griff's Avatar
you should be good on a wet 75 shot. i run a 75 dry shot with nothing but bolt ons and colder plugs on a H22A4. no signs of running lean or detonation.... just haulin ***.
btw h22 crx is quick as **** all motor. props
Old Feb 9, 2005 | 08:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgags13 &raquo;</TD></TR><TR><TD CLASS="quote">well you might be a special case...or you have only been using it for a year
get back to me in a few years when your pistons are f'd up and I'll bake you a cake that says I told you so.... </TD></TR></TABLE>
ok smart ***, you ever ran juce??? or do you...lets see....one year at a bottle every 3 weeks, whats that make...about 17 bottles, and 170lbs or so....
go eat a dick, theres your cake
Old Feb 9, 2005 | 09:28 PM
SUB-0 H23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgags13 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean? how much nitrous you can put in a mostly stock engine? if so, i wouldn't go more than a 75 shot. but that **** is no cool. eventually with a stock engine, you'll have damaged pistons valves and eat through the valve seals quicker. </TD></TR></TABLE>
stop talking out of your a$$....
a 75 shot(rated to the flywheel) is ok... just take the necessary precautions
Old Feb 10, 2005 | 07:00 AM
crxh22a4's Avatar
Default Re: nitrous??? (SUB-0 H23)
the only reason im going on the bottle is that i want to hit mid 11's......with my slicks and 1900lbs i think its enough! my mods are (type s pistons, type s cams, skunk2 cam gears, aem fuel rail, fuel presure reg.,Walbro fuel pump 255, fields vtec controller, reprogramed ecu, A.C.T extreme clutch, 6 puck disk, fadanza flywheel...........in a crx(1900lbs) ill get pictures this weekend......o ya i got the h22 skunk2 manifold and when it came in it didn't fit....!
h22 crx
12.86@106.5
h22 crx
12.86@106.5mph
Old Feb 11, 2005 | 07:31 AM
crxh22a4's Avatar
Do you think id break some axles?
h22 crx
12.86@106.5mph
Old Feb 11, 2005 | 08:12 AM
TXcivic96's Avatar
if you have a reprogramed ecu that advances your timing you may want to get rid of that
Old Feb 11, 2005 | 11:07 AM
Griff's Avatar
Default Re: nitrous??? (jdmboostedlude)
yes my thoughts exactly. Get rid of that ecu if it advances timing, and with the right tuning and your fuel mods you will be more than safe on a 75 shot.
Old Feb 11, 2005 | 12:46 PM
LudeyKrus's Avatar
YOU'RE the guy here on a forum asking for advice on spraying on a motor you know nothing about; and you're telling a guy that SPRAYS ON HIS H22 THAT HE'S WRONG?!
Bwuahahahahaha...........
Nitrous will NOT fry your rings alone; it's more how you drive the car than how much you spray.
Old Feb 11, 2005 | 03:24 PM
crxh22a4's Avatar
Default Re: nitrous??? (LudeyKrus)
what the fu#@, i didnt say anything to nobody about messing up **** on their motor, thats the other guy (chrisgags13) bro!
h22 crx
12.86@106.5
Old Feb 11, 2005 | 08:33 PM
superturboprelude's Avatar
yeah you should be fine as long as you get it tuned and use precaution
Old Feb 12, 2005 | 10:36 AM
NXLude's Avatar
As it was said, 75, just fine. Retard your timing, youll be ok. There are lots of us who have sprayed the **** outa their h22s with no problems at all. Me included, and Ive pulled it apart and seen that the pistons and valves were as good as new
Old Feb 12, 2005 | 10:45 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22a4 &raquo;</TD></TR><TR><TD CLASS="quote">what the fu#@, i didnt say anything to nobody about messing up **** on their motor, thats the other guy (chrisgags13) bro!
h22 crx
12.86@106.5 </TD></TR></TABLE>
That's why he quoted the other guy 'bro'.
Old Feb 12, 2005 | 12:00 PM
Under_Pressure's Avatar
Default Re: nitrous??? (Hawkze_2.3)
No problem here with my h22 with 75shot wet. And I run the **** outa it!
Old Feb 12, 2005 | 01:35 PM
crxh22a4's Avatar
Default Re: nitrous??? (92h22alude)
Do you feel a 75shot on my motor is good enough to hit under 8's at the 1/8th track, and how much harder is it to install a wet shot?
(should i be worried about my axles)
Old Feb 12, 2005 | 02:25 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22a4 &raquo;</TD></TR><TR><TD CLASS="quote">Do you feel a 75shot on my motor is good enough to hit under 8's at the 1/8th track, and how much harder is it to install a wet shot?
I am not so sure about the 8's, maybe. However, you don't need to be worried about axles if you used h22 axles but if you used your stock crx axles, just don't dump the clutch and pound through gears ALL the time, we understand if you have to do it sometimes, we all do . Good luck!
Old Feb 12, 2005 | 02:50 PM
edulerp97's Avatar
I think your axles should be find. As for your engine a 75 shot won't do anything to your car, but I do reccommend a MSD Digital 6 Plus because it retards your timing for you when the Nitous Activates. My friend and I are laughing gas freaks. We both squeeze like their is no tomorrow. He squeezes a 100 shot direct port wet system on his stock motor. No problems yet. I squeeze a 150 shot direct port, but motor is build. I 'll tell you direct port is the way to go. You Feel the power a whole lot better....
Old Feb 12, 2005 | 03:17 PM
Default Re: nitrous??? (edulerp97)
yea direct port
Old Feb 12, 2005 | 05:26 PM
crxh22a4's Avatar
Default Re: nitrous??? (superjunprelude)
im glad the axles wont break becuase the car is going to be running slicks(23'')... but damn i thought that with the wet 75shot it would run under 8.0 in the 1/8th, not even weighing at 1900lbs?????
detailzdelivere
Sep 17, 2009 03:18 PM
projectef
May 27, 2007 11:52 AM
JDMVTEC
Feb 5, 2004 01:08 PM
4thgenlude
Jan 7, 2004 09:49 AM
