help!
Old Dec 18, 2005 | 12:56 PM
CiSmoEk4's Avatar
Default help!
ok.. i've almost got this thing figured out.. but i need to kno what runs to the "hard" lines that are mounted to the engine cradle below the TB that point upwards?
and the routing?connection for some wierd looking plug thats around that same area?
thanks guys!
Old Dec 18, 2005 | 01:15 PM
The Weather Man's Avatar
Can we get a picture or something? I want to know what you're talking about - i don't have my lude here at the crib, so I need a reference of some sort.
Old Dec 18, 2005 | 03:27 PM
CiSmoEk4's Avatar
Default Re: (TheKINGPin)
yeah. cool.. let me go take one.. i figured out the "wierd" connector...lol.. it was for the external coil...
Old Dec 18, 2005 | 04:38 PM
CiSmoEk4's Avatar
Default Re: help! (CiSmoEk4)
here it is
Old Dec 18, 2005 | 04:39 PM
92hondalude's Avatar
looks like the PS lines that hook up to the vss. but i could be wrong
Old Dec 18, 2005 | 04:42 PM
Default Re: help! (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">looks like the PS lines that hook up to the vss. but i could be wrong</TD></TR></TABLE>
PS? Power steering? Hook up the VSS? - i think not.
They do look like power steering lines though - but they would hook up to the steering gearbox........One should be a high pressure line and the other a low pressure return line. Or they could hook up to the power steering resevoir
I didn't think the VSS had any hoses coming to it - i see a looped hose - whatever that is or.
But to be honest - i'm not sure. I'm having a hard time figuring out where that picture IS. Can you take an expanded picture? So we can see everything around it?
Old Dec 18, 2005 | 04:55 PM
BB6racer's Avatar
ya they look like ps lines. if they are the ps lines i am thinking of, then they do go into the transmission somewhere next to the vss, but not the actual vss. look on the tranny for where they hook up to, the soft lines aren't that long so the hard lines shouldn't bee too far away from eachother. look by the vss and the shifting mechanism on the transmission for 2 nipples, then connect them to the hard lines with some soft lines.
Old Dec 18, 2005 | 06:20 PM
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">ya they look like ps lines. if they are the ps lines i am thinking of, then they do go into the transmission somewhere next to the vss, but not the actual vss. look on the tranny for where they hook up to, the soft lines aren't that long so the hard lines shouldn't bee too far away from eachother. look by the vss and the shifting mechanism on the transmission for 2 nipples, then connect them to the hard lines with some soft lines.</TD></TR></TABLE>
What? Why would power steering lines go to the transaxle? They have to go to the gearbox.
We should have the rack & pinion style - it should look like this :
.................................................. .|o |
&lt;&lt;Tie Rod&lt;&lt;&lt;&lt;/_`_`_`_`_`_`_`_`_`_`_`/ &gt;&gt;tie rod&gt;&gt;&gt;&gt;&gt;&gt;
Sorry - thats the best i could do - but the holes are where the power steering lines go. High pressure on top - return line on bottom. First, make sure those lines don't go to the power steering resevoir(where you put the fluid).
Ha. That looks like a damn boat
Although not the shape - picture the dots as the power steering lines.
Also - if you don't know, the tie rods connect to the steering knuckle.
Old Dec 18, 2005 | 06:41 PM
CiSmoEk4's Avatar
thanks for the help, but there's nothing around there.. kinda wierd
anybody have their lude handy to take a look?
Old Dec 18, 2005 | 06:53 PM
CiSmoEk4's Avatar
i just found out those lines do go to a contraption at the vss to limit pressure based on speed.. i guess i left it on the other trans.. thanks for the help guys!
Old Dec 18, 2005 | 06:58 PM
95accordh22a's Avatar
yes and power steering fluid does go thru there usually
Old Dec 18, 2005 | 09:11 PM
SteveoBA8's Avatar
Default Re: help! (95accordh22a)
Those are the power steering lines that go to the vss because 4th gens come with variable assist power steering.
Old Dec 19, 2005 | 12:02 PM
BB4's Avatar
BB4
Default Re: help! (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Those are the power steering lines that go to the vss because 4th gens come with variable assist power steering. </TD></TR></TABLE>
redvelvetsi
Feb 3, 2013 06:01 AM
92BluEH-3
28
Jun 10, 2007 10:26 PM
98 blacksh
May 8, 2005 02:43 PM
SpOoNisMyFriEnD
10
Apr 1, 2005 06:53 AM
breathinez
Sep 28, 2004 05:56 AM
