Coolant problems on h22
Old Dec 26, 2005 | 01:55 PM
BoostnH22EK's Avatar
Default Coolant problems on h22
I have an H22a and on the back of the block there looks to be a drain or something, it next to the timing belt cover about half way up the block. it started shooting out radiator fluid on me does anyone know how to fix this, is the water pump bad, or is it something stupid?????
Old Dec 26, 2005 | 01:56 PM
The Weather Man's Avatar
If its shooting out coolant - plug it up
JB Weld that son of a bitch .............get a plug from Napa
Old Dec 26, 2005 | 01:58 PM
Default Re: (TheKINGPin)
well i would but it doesn't have threads or anything and i looked at my buddy's stock h22a and it has the same hole.
Old Dec 26, 2005 | 02:11 PM
Rosko's Avatar
Default Re: (BoostnH22EK)
Is it where the metal pipe goes into the block?
Old Dec 26, 2005 | 02:13 PM
delirious1520's Avatar
Default Re: (Rosko)
sounds like its the coolant hose from the water pump to the heater core... do you have the heater core hooked up?
Old Dec 26, 2005 | 02:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostnH22EK &raquo;</TD></TR><TR><TD CLASS="quote">well i would but it doesn't have threads or anything and i looked at my buddy's stock h22a and it has the same hole.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">
JB Weld that son of a bitch ............. </TD></TR></TABLE>
Old Dec 26, 2005 | 04:29 PM
AndyD's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">Is it where the metal pipe goes into the block?</TD></TR></TABLE>
That's exactly what I thought when I read his post.
Old Dec 26, 2005 | 06:03 PM
Default Re: (AndyD)
can you send me a picture of exactly where the metal pipe would go...
Old Dec 26, 2005 | 06:15 PM
BlueLude94's Avatar
I'm not sure but does the H series have a freeze plug?... If so, it's about that season.
Edit:I see you live in Flordia, Nevermind
Old Dec 26, 2005 | 06:23 PM
Default Re: (BlueLude94)
i don't think soo....i didn't start until recently...we had the motor running fine....and then it started leaking out the back of the block...
Old Dec 26, 2005 | 06:24 PM
Rosko's Avatar
I can send one tomorrow.
The pipe goes across the back of the block and goes into the block on the backside of the waterpump. It connects to the thermostat housing on the other end.
Here is link to majestic honda that shows the pipe but no the block
http://www.hondaautomotivepart...OSTAT
Old Dec 26, 2005 | 07:59 PM
jakeiscool's Avatar
Banned
Default Re: Coolant problems on h22 (BoostnH22EK)
is the h22 bleeder valve for coolant on the front or back of the motor?
Old Dec 26, 2005 | 09:08 PM
specialedition's Avatar
Default Re: Coolant problems on h22 (JakeIsCool)
The bleeder valve is on the thermostat housing.. the waterpipe could be leaking from the seal on the connection to the block. I am having a similar issue right now -- replaced all hoses which where leaking some. I still have a leak -- think it could be one or two things either oil cooler seal or the water pipe seals -- does it spray onto the backside of your lower A arm? these can be a PIA to figure out....
Old Dec 26, 2005 | 11:58 PM
SKDRCR's Avatar
Default Re: Coolant problems on h22 (specialedition)
So you say it's NOT dripping between the timing cover and the block?
Duzercivic97
12
Oct 6, 2012 06:48 PM
st_rage
13
Dec 25, 2008 09:56 AM
gotboost562
Apr 1, 2007 07:31 AM
mikestypeRR
Nov 17, 2005 01:11 PM
I8ayellowcrayon
Sep 6, 2005 05:55 PM
