LSD Question ...
Old Dec 25, 2005 | 05:49 PM
Slomies's Avatar
Default LSD Question ...
I was just wondering if it would be possible to pull the LSD part out of a JDM H22a tranny and swap it into a USDM F22b1 tranny. The only reason I ask is because the obx lsd can be put into either tranny and alot of h22 / f22 parts are interchangable. Let me know what you guys think ... thanks
95AccordVtec
Old Dec 25, 2005 | 11:01 PM
bad-monkey's Avatar
Default Re: LSD Question ... (95AccordVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95AccordVtec &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering if it would be possible to pull the LSD part out of a JDM H22a tranny and swap it into a USDM F22b1 tranny. The only reason I ask is because the obx lsd can be put into either tranny and alot of h22 / f22 parts are interchangable. Let me know what you guys think ... thanks
95AccordVtec</TD></TR></TABLE>
it's hard to say, you'd have to compare the cases of the 2 trannies. i have a feeling that if you could get the diff to fit, it'd work but that could be a big if.
Old Dec 26, 2005 | 06:55 AM
2lude4u's Avatar
Default Re: LSD Question ... (bad-monkey)
From what I understand the JDM LSD's from M2B4 transmissions are larger than the std. open differential. Making them non-interchangeable because the casing is different. Aftermarket Lsd's are interchangeable between most H/F series trannies because they are made the same size as Honda's open diffs.
pcguy760
Transmission & Drivetrain
Oct 17, 2008 11:24 PM
brandond
Nov 15, 2004 10:25 PM
mr. Grind
Dec 13, 2003 09:15 AM
NoLipRacen
Jul 20, 2003 05:43 PM
dkasakitis
Mar 19, 2003 04:39 AM
