Chirping
Old Dec 19, 2005 | 07:29 PM
lude98SH's Avatar
Default Chirping
Car is making a chriping sound but i can only hear it at idle or at very low rpms. You think this could be related to the bad ivac, which I am changing most likely 2morrow
Old Dec 19, 2005 | 07:30 PM
The Weather Man's Avatar
Do you have forged pistons? I"ve known some forged pistons to creat a chirp sound at idle.
Old Dec 19, 2005 | 07:45 PM
lude98SH's Avatar
Default Re: Chirping (lude98SH)
No internals are all stock. Only mods on the car are h/i/e.
Old Dec 19, 2005 | 07:46 PM
Ross 2.0's Avatar
In a Junkyard near you.
Could be your timing belt too.
Old Dec 19, 2005 | 07:49 PM
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Could be your timing belt too.</TD></TR></TABLE>
Could indeed be the timing belt.
What else? .......hmm...............let me think
I would bank on the belt.
Old Dec 19, 2005 | 07:51 PM
CivicSiDriver02's Avatar
It could also be a bad pulley somewhere.
Old Dec 19, 2005 | 07:54 PM
Ross 2.0's Avatar
not to mention the flux capacitor... I think honda has a recall on those.
Old Dec 19, 2005 | 07:59 PM
lude98SH's Avatar
it sounds like its coming from the opposite side of the timming belt. The car has 120k on it. Timing belt was changed once im not sure when though.
Old Dec 19, 2005 | 08:01 PM
SteveoBA8's Avatar
Default Re: (lude98SH)
Through out bearing? is one of your accesory belts wet?
Old Dec 19, 2005 | 08:03 PM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Car is making a chriping sound but i can only hear it at idle or at very low rpms. You think this could be related to the bad ivac, which I am changing most likely 2morrow </TD></TR></TABLE>
How do you have your valve cover breather and PCV routed? You don't have them routed together by any chance do you? If so, that is your problem..
Old Dec 19, 2005 | 08:10 PM
lude98SH's Avatar
Default Re: Chirping (GaRn)
No the pcv is routed back to the IM. The valve cover breather is routed to the intake.
Old Dec 19, 2005 | 08:11 PM
lude98SH's Avatar
No i didnt notice them to be wet.
Old Dec 19, 2005 | 08:14 PM
SteveoBA8's Avatar
Does the noise react at all to you engaging/disengaging the clutch?
Old Dec 19, 2005 | 08:17 PM
lude98SH's Avatar
Default Re: Chirping (SteveoBA8)
No its just if im at idle.
Old Dec 19, 2005 | 10:11 PM
DvD3's Avatar
B A N N E D
exhaust leak prolly, go under the car while its on (jack it up etc) and listen for a leak
Old Dec 19, 2005 | 10:23 PM
w1zdom's Avatar
Default Re: Chirping (DvD3)
i think i have the same problem, its usually when im engaging / disengaging clutch at low rpms =o
hondaracin24
Oct 29, 2006 01:20 AM
user 996328629
Jan 9, 2006 09:24 AM
dunkd
May 27, 2005 07:48 PM
civickidd99
Jul 7, 2003 11:12 AM
Epiphanicgurl
Feb 25, 2003 07:04 PM
