Wont Start PLEASE HELP!!
Old Dec 5, 2006 | 10:44 AM
masterp's Avatar
Default Wont Start PLEASE HELP!!
my car will crank over but there is no spark at the plugs, i tryed replaceing coil, no luck also i turn key to on position and do not hear fuel pump engage, i thought it could be my imobilizer but i shut it off completly and no luck, i have taken ditributor cap off clean rotor and cap still no luck, checked all the ecu fuses, ect and still nothing please help!
Old Dec 5, 2006 | 12:40 PM
JasonST's Avatar
Default Re: Wont Start PLEASE HELP!! (masterp)
Could be ur ignitor if ur not getting any spark. If u don't hear the fuel pump prime check ur main relay, do u hear the fuel line priming when u turn the key to "on" position, should be able to hear it clearly from the engine bay.
Old Dec 5, 2006 | 02:26 PM
prelude1897's Avatar
Default Re: Wont Start PLEASE HELP!! (JasonST)
to see if you're getting spark, take your cyclinder one plug wire out, put a screw driver inside of it, and hold it close to metal while someone cranks the car. If you're getting spark then you know your dizzy is alright, if not, then you may need a new iginitor. Also, double check and be sure your dizzy has a good connection at the plugs
platinum_rich
15
Feb 25, 2012 08:16 PM
pmey
May 26, 2009 01:11 PM
DelSlowmo
61
Feb 12, 2009 07:50 PM
hayn_integra
Oct 23, 2007 10:09 AM
vietjdmboi
Mar 8, 2005 06:33 PM
