check engine
Old Dec 5, 2006 | 09:34 PM
98lude-t's Avatar
Default check engine
ok here it goes, i rebuilt my h22 and put it all back in and i went to fire it up after i primed the oil system. put plugs back in and cranked to see if it would start nope it didnt, checked to see if there was fuel at the fpr nope. i know the pump is good its new. then i noticed that the engine light is not all the way on bright its faint and it doesnt go off. i cant hear the pump going and i can hear a clicking of this relay thats under the dash not on the fuse box right above the hood popper it has a brown 6 or 7 pin plug.
im thinking my ecu might have taking a dive. i jumped the service connector and nothing the engine light is still dim.
car has been sitting for 1 yr and 3 mos.
Old Dec 5, 2006 | 09:53 PM
98vtec's Avatar
moderator emeritus
Default Re: check engine (98lude-t)
are all the lights dim?
Old Dec 6, 2006 | 06:39 AM
98lude-t's Avatar
Default Re: check engine (B.Rabbit)
no they are not just the engine light and it cranks fine, im gonna look at it some more today. there was mice in there for a month or so i got rid of them quick i hope they didnt eat any wires.i looked and couldnt see any of the harness chewed
i will go plug my aem in and run a base map to see if the ecu is the problem.
Old Dec 6, 2006 | 07:53 AM
98lude-t's Avatar
well i found that my knock sensor is broken. that could be a small problem.
Old Dec 6, 2006 | 08:29 PM
98lude-t's Avatar
i hooked up my stocker and found my coil to be sparking constantly. and main relay clicking the same speed as coil fires.
hooked up a chipped p06 and not anything not a engine light or anything. wondering if my mainrelay or my ign switch is bad.
igot a new knock sensor and that wasnt it. im running outa options..
and i got in there with a test light and the logic grounds have power while unplugged from the ecu. then when i plug them back in they have power when the key is in the on pos. but one of them pulses. and i think thats whats causing my relay to click and not sure if its related to my coil or not but i assume its tied in.
i tired my aem and it wont evne get power to connect so im not sure where the problem is.
im getting my optima outa my other car and charging it to make sure its not a battery prob. and then i will have to go with rippin my dash apart to see what wires got fucked up by the mice if any. so i think ill go with the relay first then the po6 second and then will see if she runs or not......
anyone had there ign switch go bad or imoblizer lock u out if so let me know im going to look at pgmfi and read on how to bypass the unit.
__________________
Old Dec 6, 2006 | 08:32 PM
98vtec's Avatar
moderator emeritus
sounds like the car is losing the ability to run its electrical system.
Old Dec 6, 2006 | 09:00 PM
TheWalrus's Avatar
the car wont crank with a bad ignition switch, and most aftermarket immobilizers have a bypass somewhere under the dash...check for battery voltage at the ecu power feeds. also maybe take a look at the crank sensor...but thats a longshot
im real curious, let us know what you figure out
Old Dec 7, 2006 | 01:35 PM
98lude-t's Avatar
Default Re: (weenie)
well going to go out and fuss with it now i have a feeling its the mainrelay for no stupid reason.
Old Dec 7, 2006 | 01:51 PM
92blkJDMh22's Avatar
the 5th gen immobilizersis a bitch, everyone loves to get those reset...
Old Dec 8, 2006 | 08:29 AM
98lude-t's Avatar
Default Re: (92blkJDMh22)
well i went out and tested things with a meter and foundthat the main relay that was onlybuzingwas only sorta grounding i ground it toa god ground and then i had a check engine light that wasnt dim like before and it went offafter the fuel pump primed. now it has no spark
does the immobilizer screw with the spark also... i know alot but not about the imobs this is the first time dealing with one in my car.. im asuming there bypassable.
i will search and then try to figure out this problem.
buti got fuel pump to work now.
Old Dec 8, 2006 | 02:05 PM
98lude-t's Avatar
Default Re: (98lude-t)
fixed i guess when i put the head back on i smashed a wired and broke it next to the therostat housing. it looked conneted but found it was the one that was my problem which in turn shorted out my ign box and caused me more probelms.
i ran straight to the coil in stock form and bam fires right up.
it wasnt somthing u could see that was broken just looked smashed tested and whola...
Plum Chan
Feb 1, 2012 01:10 AM
Mr_Accord92
Nov 5, 2010 09:31 PM
the_dxB16
19
Dec 23, 2008 12:22 PM
Mr HYDE
Apr 10, 2007 08:52 PM
Jornum1
Jan 20, 2003 01:28 PM
