h23 to h22 problems
Old Oct 14, 2009 | 03:45 PM
crow4829's Avatar
New User
Default h23 to h22 problems
sorry to make this my first post but i need help. I swapped my h23 for a jdm h22 and now i cannot get it to start. was getting no fuel so i changed my fuel pump relay and still no fuel. please help
Old Oct 15, 2009 | 08:15 AM
kerry400f's Avatar
Default Re: h23 to h22 problems
What year 4th gen? I just finished my swap yesterday and it is awesome!
Also, what year motor did you order?
Old Oct 15, 2009 | 08:20 AM
92civlude's Avatar
Check G101. Its the main ECU ground. It should be at the t-stat housing. Its common to overlook this important ground connection.
Old Oct 15, 2009 | 10:52 AM
THC07's Avatar
can you hear the fuel pump prime with "key on" ???
Old Oct 16, 2009 | 03:57 AM
crow4829's Avatar
New User
the car is a 95 model and the engine is also a 95 model. and the only time i can hear the fuel pump prime is when i pull the relay out and jump the wires.
Old Oct 16, 2009 | 02:23 PM
crow4829's Avatar
New User
man thank you so much found the only wire that was close to the thromostat housing. put it on and it fired right up. once again thank you so much i have been working on it for a couple of months and would have never even thought of that. thank you
Old Oct 20, 2009 | 06:56 AM
92civlude's Avatar
Thanks for the reply! Good to know your car is running.
UK_Luder
Nov 3, 2007 02:19 PM
SolAssassin
Aug 4, 2006 01:40 PM
LudeyKrus
May 15, 2003 05:11 PM
thehatchninja
Apr 29, 2003 12:47 PM
LudEcrous
Apr 4, 2002 11:51 AM
