compression calculating help.
Old Sep 15, 2009 | 01:55 PM
Bangher4$'s Avatar
Default compression calculating help.
Im getting 12.1:1 and dont think its right. I have seen Zeal calc be wrong before
can somone please do the math and verify what the compression would be?
h23a1 block, rods, crank.
h22 type S pistons
h22a4 head.
OEM three layer gasket
I just dont think 12.11:1 sounds right.
TIA
Old Sep 15, 2009 | 02:30 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Default Re: compression calculating help.
Do you know the piston to deck height?
Old Sep 15, 2009 | 04:02 PM
5SpdH22's Avatar
something gnarly
Ok, I'm getting 10.54:1 using a piston to deck clearance of zero... which is way off from what zeal said.
If you know your clearance, try putting it in here..
CR = (38.06867 + clearance) / (3.61117 + clearance)
edit: My work, anybody see anything wrong?
Old Sep 16, 2009 | 08:03 AM
Bangher4$'s Avatar
yea, thats why im asking. it looks right but w/o DC then... blah
ttt
Old Sep 16, 2009 | 08:49 AM
NirVTEC's Avatar
http://www.bsperformance.com/compcalc/compcalc.htm
Old Sep 16, 2009 | 09:13 AM
5SpdH22's Avatar
something gnarly
Looks like -.02 for H22A pistons in a H23A1 block. I'm guessing the Type S ones are the same, except they have the 3.9 cc dome.
Unfortunately, it looks like that calculator is assuming you have H22 rods which could be why it gives 11:1. Since yours are shorter, I got 10.6:1 with the pistons being .02 out of the hole. Only problem is, they might not be that far out because of the shorter rods.. ugh.
Old Sep 16, 2009 | 02:58 PM
Bangher4$'s Avatar
Right but im using the h23 rods/crank with typs pistons. I used two different calculators and got two answers, 12.11:1 and 12.25:1
I dont see how your getting 10.6:1
jdm-addik
Mar 6, 2012 03:39 PM
kazino42
May 22, 2005 09:44 AM
Nisif
14
Mar 10, 2005 04:45 PM
civicsitek GanGsTa
24
Jun 17, 2004 04:22 AM
