cooling fan relay
cooling fan relay
hi i have a 94 h22a prelude and i want to hook a toggle to my cooling fan but i can seem to find the relay? I have read some forums and said its clipped to the inside of the fender next to the battery but all i can see is a little fight box not a black box from what the pics from other forums. if anyone can tell when where it is that would be great.
Re: cooling fan relay
ok I have done some troubleshooting and found this out: my fan seems to come on when I turn my car off but will not come on when the car gets hot. if i take the relay out and just the 2 pins the fan turns on. Im not sure where the switch is to check that...i was planning on just hooking up a toggle threw the relay but i cant seem to find the wire running the relay from the fuse box. i was just going to stick a wire in the relay and then stick the relay back in place with the wire in there but that will look crappy. if someone can tell me where the "green" wire is to the fan relay that would be great
peacexisxfree
01-19-2014 01:29 PM
