Compression ?
Old Jun 5, 2006 | 01:10 PM
lude98SH's Avatar
Default Compression ?
Ive been on here before and said that my compression was 150 across. You guys said thats fine and i checked my manual and it confirmed that everything is fine. But why are most ppls reading around 200 or more and mine is 150 ?
Old Jun 5, 2006 | 01:41 PM
homesauce's Avatar
Default Re: Compression ? (lude98SH)
It should be a consistent number, and you can try a different gauge, they can have different calibration. It should be a bit higher for an H22A4, but like I said, try a different compression tester if it bothers you that much. As long as you don't feel power loss/burning oil, you shouldn't worry too much about it.
Old Jun 5, 2006 | 02:18 PM
prelude1897's Avatar
most H22a4 motor are usually around 200-215....A friend of mine's H23 was hitting between 190-215 with rod knock
Old Jun 5, 2006 | 09:55 PM
Buffalo's Avatar
Default Re: Compression ? (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">....A friend of mine's H23 was hitting between 190-215 with rod knock</TD></TR></TABLE>
with the same tester?
Old Jun 6, 2006 | 06:31 AM
Default Re: Compression ? (Buffalo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buffalo &raquo;</TD></TR><TR><TD CLASS="quote">
yep..We used a brand new tester when we tested his motors compression
cammilian
Jan 9, 2009 09:33 AM
delguiner
Aug 17, 2004 01:44 PM
95kupEX
Jan 16, 2004 11:03 PM
del_parker
Sep 24, 2003 08:57 PM
ixcryxblood
Jun 23, 2003 06:19 AM
