Replacing Knock Sensor
Old Jun 1, 2006 | 06:02 AM
vinuneuro's Avatar
Default Replacing Knock Sensor
What is actually involved in replacing it? I understand it's in the back of the block, but I have an SH, so would it still be in the same location?
Old Jun 1, 2006 | 06:14 AM
sharkcohen's Avatar
Default Re: Replacing Knock Sensor (vinuneuro)
You have to either remove the ATTS to get to it from below, or remove the intake manifold to get to it from above.
Old Jun 1, 2006 | 10:22 AM
SteveoBA8's Avatar
Default Re: Replacing Knock Sensor (sharkcohen)
yep/\ , shouldve bought a base .
Old Jun 1, 2006 | 11:15 AM
93ludesitec's Avatar
Default Re: Replacing Knock Sensor (SteveoBA8)
what about on a 4th gen???? i think i can get to it from the bottom, but im not sure yet, and help???
Old Jun 1, 2006 | 11:24 AM
NoVALude's Avatar
Default Re: Replacing Knock Sensor (93ludesitec)
I have an H22A4 in my 4th gen, and if you take off the oil filter, I was able to reach the knock sensor....kinda tight, but it is do-able.
Old Jun 1, 2006 | 11:52 AM
98TypeSH's Avatar
Default Re: Replacing Knock Sensor (NoVALude)
Gotta remove the intake manifold to get to that SOB on the SH.
Such a pain in the ***. You will most likely end up dropping a few intake mani bolts and they will just disappear into thin air. Buy a few extras from the stealership.
Make sure the wire comming from the loom to the sensor is still intact. your knock could still be good but the wire got botched.
Old Jun 1, 2006 | 02:21 PM
Default Re: Replacing Knock Sensor (98TypeSH)
cool thanks man.... i gotta do that soon, does anyone know if the b16a uses the same knock sensor as the h22a, i have a sensor from one, and want to put it on mine!
Old Jun 1, 2006 | 07:06 PM
SteveoBA8's Avatar
I replaced mine in my 4th gen a while back no prob, just remove the oil filter and you can easily get to it. The atts unit blocks you from accesing it from the bottom on a 5th gen SH like stated before.
Old Jun 1, 2006 | 08:19 PM
vinuneuro's Avatar
That's pretty shitty guys...removing the im.
Is there a section in the helms that shows you how to remove it? In the intake manifold replacement section, all there is, is a break down of all the parts it consists off.
btw, i'm replacing the knock sensor in hopes that it fixes my mid-range hesitation like it did for so many of you.
Old Jun 2, 2006 | 06:07 AM
sharkcohen's Avatar
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty shitty guys...removing the im.
Is there a section in the helms that shows you how to remove it? </TD></TR></TABLE>
No there's not, and it's a bitch to remove it in the SH.
CChong
Jan 16, 2017 02:53 PM
Derek88
Jun 17, 2007 03:47 PM
schwett
Jun 20, 2002 12:41 PM
AustinTXRules
Jul 25, 2001 07:28 PM
