engine smoking problem
Old Jun 1, 2006 | 01:46 PM
homesauce's Avatar
Default engine smoking problem
So, my engine is still smoking periodically, and it is definitely burning oil. I've run out of ideas. Any ideas are appreciated
This is what I've done/checked.
1. Compression good on all cylinders
2. Turbo is dry on turbine side
3. Head gasket changed
4. Valve seals changed.
Should I change the PCV valve, or would that be a waste of time, since it is smoking quite a bit.
Old Jun 1, 2006 | 04:19 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: engine smoking problem (homesauce)
valve stem seals? or rings...that sucks dude
Old Jun 1, 2006 | 06:08 PM
homesauce's Avatar
Default Re: engine smoking problem (I got the CD5 Jeebies!)
i just finished replacing the valve seals, and perfect dry compression would suggest good piston rings (plus I just looked into my block when my head was removed, everything looked fine), any other ideas ?
Old Jun 1, 2006 | 11:56 PM
bigdaddyvtec's Avatar
* B A N N E D *
If it smokes out the breather on decell probably the ringlands.... What do your A/FS look like??? Have you done a leakdown test??? How do your plugs look??? What about the compressor side of the snail/inside charge pipes.......
Old Jun 2, 2006 | 12:24 PM
homesauce's Avatar
Default Re: engine smoking problem (bigdaddyvtec)
Just drove it today, couldn't boost, and heard rickety sounds from the turbo. It's the turbo, just didn't notice it before since it was still building boost.
Weird though, since it was rebuilt just 15K miles ago. Must have been something with the oil pressure.
youryanyou
Apr 5, 2010 08:14 AM
th3pwn3r
Aug 5, 2008 06:32 PM
bigempty12
Mar 11, 2008 07:01 AM
chickenandpickles
Aug 30, 2005 11:21 PM
Will Albers
Feb 6, 2004 04:15 PM
