Climate Control Problem Please Please Pleaseeee Help
Old May 31, 2006 | 11:11 PM
BoominPrelude's Avatar
Default Climate Control Problem Please Please Pleaseeee Help
Hi, i'm having a major climate control problem, my temp will only work on high, speed 1-3 do not work at all, but the a/c fan still clicks on.. i replaced the blower motor resistor which almost imediately after install..the little metal part started to melt & come apart like the old one, fan works on all speeds but air only comes out on highest speed, what could be the cause of this? couls it be short to ground? or possibly something else, also checked fuses? if anyone could help i would much apreciate it.. no one has been able to tell me what's wrong
Old May 31, 2006 | 11:35 PM
MLBZ521's Avatar
Default Re: Climate Control Problem Please Please Pleaseeee Help (BoominPrelude)
If something is melting and falling apart like I think you're saying, you have some wiring issues... You have a problem with something not wired up correctly.. Sounds like the wires aren't going into that part right and it's burning it up.
I could be wrong though as I have not done this swap... *yet*..
Good luck with it though!
Old Jun 1, 2006 | 12:45 AM
Default Re: Climate Control Problem Please Please Pleaseeee Help (MLBZ521)
It's 5th Gen.. would it be the same? i've heard of doing that with the resistor, but i think it's just going to melt apart again, the replacement part was from honda.. no refunds.. i'm thinking it's wiring, which means i'm going without a/c & heat.. because i don't wanna know what honda would charge
journeyquest
Aug 3, 2015 05:30 AM
itr1448
Feb 18, 2010 09:31 PM
projektCRX
May 21, 2007 11:23 AM
tidrab
Jul 30, 2004 08:10 AM
rwcdrums
Feb 2, 2003 12:52 AM
