Compression and nitrous with 93 octane
Old Jun 4, 2006 | 06:30 AM
kornerk12's Avatar
Default Compression and nitrous with 93 octane
How hard is it to run a decent sized shot of nitrous with high compression pistons. Will be running forged pistons and sleeved block. Also will have large injectors and walbro 255 fuel pump. This is assuming it will be tuned well. Am i still at risk for detonation or any other problems ?
Old Jun 4, 2006 | 07:10 AM
SKDRCR's Avatar
Default Re: Compression and nitrous with 93 octane (kornerk12)
Well, what do you consider a decent sized shot?
I think you could still run a 65 shot as long as you take
the proper precautions.
High compression and boosting is a lot harder to do safely.
Old Jun 4, 2006 | 07:14 AM
kornerk12's Avatar
Default Re: Compression and nitrous with 93 octane (SKDRCR)
I was thinking possibly a 100 shot but its more so whatever i can safely run.
Old Jun 4, 2006 | 07:18 AM
DIRTYsouthBB6's Avatar
You might want to experiment with the spark plugs and timing too
Old Jun 4, 2006 | 03:47 PM
AzCivic1.6's Avatar
get a device that retards timing while spraying, like the MSD digital 6. if your running a shot that big its probably a wet kit so bigger injectors don't matter.
Old Jun 4, 2006 | 04:00 PM
lude of pre 2.3's Avatar
if it is a sleeved block with rods and pistons id say it would be fine to run up to a 150 shot with the right timing map and mabey a little race gas MSD makes a 6BTM ignition box with timing retard would work great for your application post some #'s when ur done
Old Jun 4, 2006 | 11:14 PM
hu's Avatar
hu
Aren't you worried about blowing your piston rings out?
Old Jun 5, 2006 | 12:57 PM
kornerk12's Avatar
Default Re: (hu)
I have the MSD SCI Plus im in the process of installing it now but i cant find much room in the bay for it.
Old Jun 5, 2006 | 01:21 PM
md23vtec's Avatar
Whats your CR ratio?
Old Jun 5, 2006 | 01:37 PM
kornerk12's Avatar
Default Re: Compression and nitrous with 93 octane (md23vtec)
not sure i wanted to do somewhere around 12.1 or higher
Old Jun 5, 2006 | 01:42 PM
md23vtec's Avatar
So you havent done the build yet . If your going to spray on pump gas why not go with lower compression?
Old Jun 5, 2006 | 01:48 PM
kornerk12's Avatar
because my goal originally was to do a good all motor build. Spray wasnt something i originally planned on but am looking into.
MrChrisDurban
Jan 9, 2015 01:21 PM
lude98SH
43
Jan 16, 2007 07:38 PM
jdmlife
15
Aug 12, 2004 10:08 AM
GOLDBERG
Aug 5, 2003 07:41 PM
MEANB18
Dec 27, 2002 09:18 AM
