Repair or Replace IAC
Old Jul 3, 2007 | 04:17 PM
InvaderTrax's Avatar
Default Repair or Replace IAC
My check engine light came on and the car wouldn't idle afterwards. Cleared the code and it idled, but very low. Light came back on, so I checked it and it was code 14, IAC valve. I know that when the idle jumps cleaning it can help, but what about when there is no idle?
Old Jul 4, 2007 | 08:29 AM
Anyone?
Old Jul 4, 2007 | 08:35 AM
Hawkze_2.3's Avatar
Default Re: (InvaderTrax)
I'd inspect the IACV and clean it if you can...also inpect the electrical connectors and coolant hoses. If you can't fix it, just get a new one.
Old Jul 4, 2007 | 09:56 AM
lude98SH's Avatar
Default Re: (Hawkze_2.3)
im sure there is some kind of spec for the resistance the sensor should have.
Old Jul 4, 2007 | 11:08 AM
prelude_93vtec's Avatar
Default Re: Repair or Replace IAC (InvaderTrax)
ya i had a code 14 a lil bit ago. i cleaned out the valve and problem solved. if anything, you can just get a new one theyre pretty cheap
Old Jul 4, 2007 | 02:55 PM
Default Re: Repair or Replace IAC (prelude_93vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">ya i had a code 14 a lil bit ago. i cleaned out the valve and problem solved. if anything, you can just get a new one theyre pretty cheap</TD></TR></TABLE>
Advance quoted me $250. Anyway, I pulled it off, and on the manifold side, the screen was caked with carbon. I put some carb cleaner on a rag and wiped it off, and it seems to be working fine now
yoffer
May 31, 2007 11:54 AM
SONIC BOOM
Jul 10, 2006 10:54 AM
r1de4life
Jan 14, 2006 03:49 PM
ko
May 22, 2005 10:54 PM
Kooneryfz450
Mar 1, 2005 01:37 PM
