transmision removal from the engine
Old Jul 3, 2007 | 06:56 PM
UltimX's Avatar
Default transmision removal from the engine
Besides the six bolts or so and the dust shield, what else do you need to remove if anything inorder to seperate the tranny from the block? No mounts are on the tranny/engine, and i don't want to use screw drivers and pry on the block and tranny damaging the casings. is there any other way besides the pry bar? they don't have a bolt you can screw in the casing or something inorder to seperate it from the engine? IE disc on the hub, you use a screw to seperate it from the hub. thanks for your help guys.
Old Jul 3, 2007 | 07:15 PM
xxmastermindxx's Avatar
Default Re: transmision removal from the engine (UltimX)
i couldnt really think of any other way, and i've done that separation 3 times so far. i usually just stick a pry bar in the timing window of the block, there was never a need for major torque/prying, never did any kind of damage. just a little nudge to get it started, then wiggled it the rest of the way out.
Old Jul 4, 2007 | 05:42 AM
mattsnooz's Avatar
Default Re: transmision removal from the engine (xxmastermindxx)
yeah x 2
Or bump it with big rubber mallet (on either sides) while tranny is being supported of course
Old Jul 4, 2007 | 06:02 AM
117's Avatar
117
It shouldn't take more than just a bit of pressure with a pry bar to separate the trans from the engine. I've always used a pry bar and never had damage from it. If you're worried about it, cover the pry bar with a shop towel.
Old Jul 4, 2007 | 07:00 AM
MooJenLude's Avatar
X2 worked for me
Old Jul 4, 2007 | 08:22 AM
UltimX's Avatar
Default Re: (MooJenLude)
thanks a bunch guys, i was wondering if thats the only way. i used a rubber mallet but it didn't work. i'll try again.
Old Jul 4, 2007 | 09:45 AM
M2B4's Avatar
Default Re: (UltimX)
i used a rubber mallet and a screw driver lol bout to havta do it again
Old Jul 4, 2007 | 01:39 PM
blake92lude's Avatar
Yea, I'm about to take my block outta the car, so this info will more than likely be useful to me as well....
Megaton22
Nov 8, 2016 10:24 AM
serg92hatch
Aug 27, 2010 03:50 PM
B18C_EJ8
Nov 5, 2007 06:36 PM
dolphus731
Nov 4, 2005 05:42 PM
Mario
Mar 15, 2002 07:36 PM
