Unplugging Knock Sensor.
Old Jul 3, 2007 | 09:13 AM
racer69's Avatar
Default Unplugging Knock Sensor.
If you unplug the knock sensor, it will throw a code but will it also keep from retarding the ignition timing? I am trying to figure out what is causing my low rpm hesitation. It won't hardly move from the start.
Old Jul 3, 2007 | 09:17 AM
carnot's Avatar
Default Re: Unplugging Knock Sensor. (racer69)
I think if you unplug the knock sensor that the ECU will go into a safe mode and retard the timing a lot. have you checked out your ignition components? spark plugs etc?
Old Jul 3, 2007 | 09:18 AM
Finest's Avatar
If it throws a CEL, it might revert to limp mode.
What mods do you have on the car? Mileage? Have you tried cleaning out your EGR ports? Check HERE for other solutions.
Old Jul 3, 2007 | 09:35 AM
racer69's Avatar
Default Re: Unplugging Knock Sensor. (Finest)
It is a stock motor with about 40k (engine swap) miles. The cap,rotor, and plugs are all good. Timing was set at 15* BTDC. It is a 94 H23 and I only have this problem when it warms up. It is great when cold.
Old Jul 3, 2007 | 09:37 AM
117's Avatar
117
Be VERY VERY careful when unplugging the knock sensor. The plastic connector becomes very brittle and it is easy to break. If you break it, it's over $100 for a new one, even from discounted Honda suppliers.
Old Jul 3, 2007 | 10:12 AM
carnot's Avatar
let me make sure i understand the problem correctly. At low rpm with the motor up to temp to car feels low on power. At low rpm when the car is still cold the car moves out just fine? Its starting to sound like it could be a fuel delivery probem.. like the motor is getting too much fuel after it warms up and this causes it to be low on power.. How is your gas mileage?
Old Jul 3, 2007 | 10:26 AM
racer69's Avatar
Default Re: Unplugging Knock Sensor. (carnot)
My gas milage is horrible. I didn't even get 20 mpg on this tank and it was all highway miles. I just checked the timing while it is acting up and it was way off. I couldn't get it to 15*BTDC.
Old Jul 3, 2007 | 10:37 AM
prelittlelude's Avatar
no knock or bad knock will retard timing alot, and add a **** load of fuel,
Old Jul 3, 2007 | 10:49 AM
racer69's Avatar
Default Re: Unplugging Knock Sensor. (prelittlelude)
OK, I just advanced the timing as far as I could and it took of like new. Then driving around a little it started going back to no power like something was retarding the ignition timing. Is the knock sensor the main culprit for retarding timing?
Old Jul 3, 2007 | 10:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer69 &raquo;</TD></TR><TR><TD CLASS="quote"> Is the knock sensor the main culprit for retarding timing?</TD></TR></TABLE>
YES!
tommyistommy
Jan 24, 2009 04:57 AM
civicgsr499
14
Nov 13, 2008 06:28 PM
co_OlLo_OdDo_Od
May 3, 2006 11:36 PM
crix868
Dec 21, 2005 11:50 AM
untitledsn41
Jul 30, 2004 04:48 AM
