Easy Question.....Need definate Answer!!!
Old Jun 29, 2005 | 10:38 AM
H22EKHATCH's Avatar
Default Easy Question.....Need definate Answer!!!
OK guys here's my stupid question of the month...............
I dropped the lower portion of my exhaust manifold (H22a) to replace my oil pan the (bolts) were seized so they broke...
I ordered new ones from Honda & recieved 3 STUDS now I know I had pulled out bolts (possibly replaced previously) but....
Question Is Is the upper & lower portion of the exhaust manifold held together with STUDS or BOLTS.....(from factory)
thank you In advance
Old Jun 29, 2005 | 10:43 AM
Honda318dx's Avatar
Default Re: Easy Question.....Need definate Answer!!! (H22EKHATCH)
its not a stupid questions, but, what does it matter weather you use a stud or bolt?
Old Jun 29, 2005 | 10:52 AM
H22EKHATCH's Avatar
Default Re: Easy Question.....Need definate Answer!!! (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">its not a stupid questions, but, what does it matter weather you use a stud or bolt?</TD></TR></TABLE>
Well I was expecting bolts to come in from Honda....being that I took bolts out...
But I just recieved Studs......and was wondering if Honda F*cked up or if someone had replaced these studs at some point.....
I am walking to get parts right now so I'm not picking them up till I know they're right.......(and yes unfortunatly all harware stores are out of walking distance)
thanks....three bolts or studs are stopping me from driving?....I know, I know
Old Jun 29, 2005 | 10:56 AM
JonGP4's Avatar
from the factory.. it has studs.. most likely someone else put those bolts in there
Old Jun 29, 2005 | 10:59 AM
H22EKHATCH's Avatar
Default Re: Easy Question.....Need definate Answer!!! (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">from the factory.. it has studs.. most likely someone else put those bolts in there</TD></TR></TABLE>
Figured as much................... thank you..........................
leroy12
Feb 12, 2010 12:41 PM
ef dino
Oct 31, 2007 04:46 AM
o'malley_808
Aug 21, 2006 04:44 PM
mrrugsr
Mar 1, 2006 08:00 AM
redboost10
Jan 22, 2004 08:06 PM
