fan doesnt work
Old Jan 23, 2006 | 06:46 PM
93h22a1vtec's Avatar
Default fan doesnt work
My fan doesnt work since i took my motor out the first time. Anyone have any suggestions as to why it wont work? or things i could check for. I check the fuse and it was blown, replaced and it sitll wont turn on. What else could be wrong?
93 prelude vtec
Old Jan 23, 2006 | 07:05 PM
The Weather Man's Avatar
Who cares?.........although this is a "cheap-way-out".......just get the two wires, ground one to the chasis and connect the other to the ignition - or a switch.
Old Jan 23, 2006 | 07:27 PM
Default Re: (TheKINGPin)
i care, the fan drains power, and i dont want it on all the time, im thinkin bout just wireing it to a switch, which is what i will prolly do
Old Jan 23, 2006 | 07:37 PM
SteveoBA8's Avatar
Default Re: (93h22a1vtec)
Apply 12v to each fan and see if they actually work, but sounds like an open wire somewhere since you replaced the fuse and still nothing. Could also have a faulty cooling fan timer unit(right beside the ecu), radiator fan relay(under hood fuse box), condensor fan relay( by powersteering res).
Old Jan 23, 2006 | 07:56 PM
roller3804's Avatar
Check that the ECT switches are functioning correctly. That is what triggers the fans to come on at hot temps. MY car did this when I first had it. Did u flash the ECU memory?
Old Jan 23, 2006 | 07:58 PM
HB VTEC's Avatar
if your in a hurry..you can us a toggle switch until you can figure out the problem
Old Jan 23, 2006 | 11:13 PM
hu's Avatar
hu
Go to the dealership and get a new relay.
Old Jan 23, 2006 | 11:30 PM
jdmlude_dude's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camrann &raquo;</TD></TR><TR><TD CLASS="quote">Check that the ECT switches are functioning correctly. That is what triggers the fans to come on at hot temps. MY car did this when I first had it. Did u flash the ECU memory?</TD></TR></TABLE>
could you explain without the lingo? i have the same problem. what is the ECT? flash the ECU memory? i have checked everything and hotwired the fan itself. all relays have been replaced as well as every sensor on the head that would have anything to do with cooling.
Old Jan 24, 2006 | 04:47 AM
roller3804's Avatar
Default Re: (jdmlude_dude)
sry. ECT is Engine Coolant Temperature. And flashing the ECU memory is resetting the engine computer. You do this by unhooking the negative battery cable for 30 seconds or so. That just clears everything and lets teh ECU start fresh.
The switches and sensors on the head are the ones IM referring to.
There are two ECT switches and one ECT sensor I believe. Look in your manual to see where they are and it shows you how to test them. If you need a manual i can provide you with one.
Is your car just over heating? or is the fan not coming on?
Old Jan 25, 2006 | 02:00 PM
Default Re: (camrann)
just no fan
i havent overheated yet, but i dont let it idle long, and it is winter
apexi_rsx
Jul 19, 2013 07:43 PM
clowery89
Jun 23, 2010 06:17 AM
ek_silverback
Dec 22, 2008 09:29 PM
93h22a1vtec
Mar 11, 2006 09:57 AM
Nos4R2
Jan 26, 2003 09:40 PM
