Problem: running rich?
Old Jan 25, 2006 | 06:50 AM
Mik3's Avatar
Default Problem: running rich?
it's a 99 prelude and every time i pull the spark plugs they are wet with fuel. Are they supposed to be like that? I'm throwing codes 45 71 and 72. The car bogs sometimes and hesitates when i step on the gas. PLEASE HELP!!
Old Jan 25, 2006 | 06:56 AM
Iamcuddles's Avatar
Default Re: Problem: running rich? (Mik3)
I know 71-72 are misfires. Check the FAQs, I think they have the codes on this site for the Prelude. How long have you been driving around like that?
Old Jan 25, 2006 | 07:42 AM
Mik3's Avatar
Default Re: Problem: running rich? (Iamcuddles)
It's been like this for awhile but i know that 45 is "System running too lean/rich". BUMP
EDIT: Could running rich cause the misfires?
Old Jan 25, 2006 | 10:39 AM
951dc5's Avatar
man that happened to me before. You got to check all your sparking stuff such as spark plugs and cap. make sure the wires are all the way making contact with the plugs. theres no spark to combust the air/fuel so fuel appears there.
Old Jan 25, 2006 | 11:20 AM
brolli's Avatar
Default Re: Problem: running rich? (Prelude951)
is code 45 mean its running lean or rich. if your car is missing, the 02 sensor will see it as a lean condition. if the code is for a rich condition then i wouldnt think its missing.
Old Jan 25, 2006 | 12:42 PM
Mik3's Avatar
Default Re: Problem: running rich? (brolli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">man that happened to me before. You got to check all your sparking stuff such as spark plugs and cap. make sure the wires are all the way making contact with the plugs. theres no spark to combust the air/fuel so fuel appears there. </TD></TR></TABLE>
Could it be that it's not getting enough of a spark to ignite that fuel or is it getting to much fuel? The motor would eventually run after a while of cranking it.
Old Jan 25, 2006 | 07:28 PM
ed_1's Avatar
I would start with the spark plug wires, cap, and rotor.
Old Jan 25, 2006 | 07:34 PM
CivicSiDriver02's Avatar
Default Re: Problem: running rich? (ed_1)
Yea I would bet it is because of lack of spark rather than excessive fuel. Is it misfiring on all cylinders?
Old Jan 26, 2006 | 06:35 AM
Mik3's Avatar
Default Re: Problem: running rich? (CivicSiDriver02)
CEL 71 and 72 are misfires on cylinder 2 and 3.
charlie0801
Sep 8, 2007 08:07 PM
Baron55
Jul 2, 2007 02:32 AM
MOVE OVER
Oct 4, 2005 04:31 PM
Art Vandeleigh
Mar 29, 2005 10:34 PM
B00ST2nR
Oct 19, 2002 02:36 PM
