Ecu problem/Fuel Delivery problem
Old Jun 7, 2022 | 07:47 PM
Cornbread3's Avatar
Default Ecu problem/Fuel Delivery problem
1993 Honda Prelude dirt circle track car
H22
Stand alone harness
Dyno tuned and chipped ecu p28 I think
My last race I ran I didn't have my gearing choice right, so I was bouncing off of the Rev limiter quite a bit. On the last lap of the race, the car sounded like it lean out and then just shut off. Wouldn't start back.
After I got back to the pits, I put more fuel in the car and it started right up. I went back out for the next race and as soon as I mashed the throttle it did the same thing and started bucking and backfiring and all that but didn't shut off this time so I pulled it in. I figured my walbro 255 fuel pump had but the dust.
I bought another fuel pump and replaced it and I still have the same issues. The car will start up but sounds bad and pops and cracks when I give it throttle.
Things I have checked
- fuel pressure which was 50 psi
-made sure my 500cc injectors were clicking and not leaking
-no fuel constricting in hoses, no clogs, new fuel filter
-Compression check, all cylinders were good
-leak down test, all cylinders were good
-checked all sensors for correct operation all good
- spark plugs are fine
- swapped out distributors, nothing changed
-swapped out vtec solenoid, nothing changed.
-swapped out stock fuel pressure regulator, no change
I'm at a loss as what has happened. Car ran great and all of a sudden going into a corner it started cutting out and popping and cracking and hasn't been the same since.
Any help is appreciated. Thanks
Old Jun 9, 2022 | 07:18 AM
ross2004's Avatar
Default Re: Ecu problem/Fuel Delivery problem
Double check the TPS & main relay.
Twisted Image
Mar 2, 2008 05:07 PM
3.point.2
Dec 16, 2006 01:12 PM
JDMhondalude22
Oct 26, 2006 02:19 PM
Maxime
Jul 10, 2005 05:46 AM
MAYHEM
41
Mar 6, 2005 05:43 PM
