CEL code reading.. OBD
Old Jun 26, 2024 | 01:21 PM
danielelihansen's Avatar
Default CEL code reading.. OBD
I’m new to this method but wanted to give it a try but it doesn’t seem to work.
Paper clip method into the 2-pin connector and then read the blinks to find the errors.
Problem is — my CEL doesn’t blink it just stays on solid when turned to ON position.
I’ve seen that some had luck with the engine running as well. That didn’t help for me either.
anyone have an idea why my light stays on and refuses to tell me the code?
Old Jun 26, 2024 | 10:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: CEL code reading.. OBD
You have one of three possibilities:
1) You aren't inserting the paper clip properly into the 2-pin service connector.
2) The ECU is damaged. It can also be a chipped ECU and the calibration on the chip has a "phantom" code... which means an incongruity in the ECU programming. Example: The knock sensor isn't turned off in the calibration of a P28 ECU... which doesn't have knock circuitry.
3) You have no stored codes and thus, the CEL stays on solid when you inserted the paper clip. This may be because you have turned the key off after the CEL came on, and without a functioning back up memory circuit, the code is reset. At key on, you have no code.
Old Jun 27, 2024 | 01:11 AM
I know that the clip is inserted correctly as my ABS light also comes on with the clip in.
And as soon I take the clip out the ABS light shuts off and then the CEL dims down.
How do I get the codes then or is it simply just buying a new ECU?
GriFFIthS
Honda Civic (2001 - 2005)
Feb 21, 2011 04:26 AM
1251_ks
Oct 7, 2010 03:39 AM
karrar55
Aug 29, 2009 04:52 AM
1SlowB16EF
Feb 25, 2006 07:41 AM
emanLS
Oct 20, 2003 01:15 PM
