need help quick please...
Old Jul 22, 2003 | 12:39 AM
ATF Kuk's Avatar
Default need help quick please...
my friend converted auto to stick, but those bastards didnt change ecu and now theyre out of buisness so we cant find them. when the check light came on, they just unplugged the CEL from the cluster so u cant see it. he needs to pass smog and he needs to find a stock 97 5speed ecu.
the code and if anyone has one for sale would be very helpful. thanx
Old Jul 22, 2003 | 06:31 AM
Sephro's Avatar
Default Re: need help quick please... (ATF Kuk)
Best advice I can tell you is that if no one here has one check out
http://www.car-parts.com I just checked and it found 3. 2 here in MA and one in CA. Around $230-$250 though...
Old Jul 22, 2003 | 11:59 AM
ATF Kuk's Avatar
Default Re: need help quick please... (Sephro)
thanx, do u know the ecu code?
Old Jul 22, 2003 | 12:02 PM
JBG's Ferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">thanx, do u know the ecu code?</TD></TR></TABLE>
are you wanting to know what ecu he needs? i.e a p13 or p28? I don't understand what you're trying to ask.
Old Jul 22, 2003 | 07:06 PM
ATF Kuk's Avatar
Default Re: need help quick please... (J B G)
i need to know wut ecu he needs. example P28 P73 P30... thanx
Old Jul 22, 2003 | 07:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk &raquo;</TD></TR><TR><TD CLASS="quote">i need to know wut ecu he needs. example P28 P73 P30... thanx</TD></TR></TABLE>
p13
Old Jul 22, 2003 | 11:15 PM
ATF Kuk's Avatar
obd2 p13 right? i always thought p13 was obd1. also, do u know if 96-98 obd2 p72 will plug right in without modification and also will it pass smog with it. i know that the 96-98 p72 didnt immobilizer.
Old Jul 23, 2003 | 03:06 AM
https://honda-tech.com/zerothread?id=567799
that should answer any questions you have about ecu's.
yes obd2 p13
Cashieboi
15
Jun 21, 2007 10:18 AM
rickturboteg
Oct 2, 2006 11:09 PM
RAS Motorsports
Nov 3, 2004 08:54 AM
Brewer
Jul 7, 2004 01:49 PM
td04civic
Oct 2, 2002 08:11 PM
