4th gen shift linkage...
Old Jul 19, 2003 | 04:03 PM
h23atsi's Avatar
Default 4th gen shift linkage...
i'm currently in the middle of putting my engine back in, and while i was at it i thought i'd do a 5-speed swap. :D i need to know if the shift linkage is run over or under the rear beam and if it has to run from the drivers side of the rear motor mount or the passenger side. the linkage is the only thing i have left to do to complete the swap so all help would be appreciated.
oh and if any one can take some pics of the linkage routing so i could get a visual that would be awesome
thanks
Old Jul 19, 2003 | 08:45 PM
Honda318dx's Avatar
Default Re: 4th gen shift linkage... (h23atsi)
over the subframe, and to the left of the rear motor mount, I think...
Old Jul 19, 2003 | 09:10 PM
h23atsi's Avatar
is that left drivers side or left passenger side of the motor mount? anyone else?
Old Aug 12, 2004 | 11:53 AM
92-LS-Civic's Avatar
Default Re: (h23atsi)
hey, i am thinking of trying to swap a JDM h22, and at the same time converting the car to manual... did you get yours done yet? how did the shift linkage hook up? how hard was it to put in the shifter and every thing else related? how hard was it to put in the clutch pedal? thanks alot.
Old Aug 12, 2004 | 11:55 AM
Greyout's Avatar
Default Re: (zdowell17)
how easy is it to punch out the hole in the firewall?
and if I remember correctly, the only way to get linkage at the proper angle is to go around the driver's side of the mount, and underneith it. Any other way, and it doesn't fit.
edit: heres a pic
right click, cut, paste, and add .orig.jpg for the big version
Old Aug 12, 2004 | 03:19 PM
satan_srv's Avatar
Default Re: (Greyout)
there is a mounting point on the subframe and a bracket that attaches the linkage on the back top of the subframe if you attach that it will be pretty obvious where the linkage will go
92egvx
Jan 24, 2011 08:31 AM
hotxcivic92
Mar 7, 2008 11:35 AM
evilsolb16
Sep 26, 2004 01:33 PM
TIRENECK
Mar 24, 2004 09:43 PM
