slight running problem
Old Jul 25, 2003 | 10:41 AM
preluder's Avatar
Default slight running problem
okay when im at a standstill I start off to let my car roll of from the start. ITs idle is at 800-850 or so when i release it takes the mean dip in at 200 -300 rpms and it boggs so i have to give it extra gas so I can take off what must be done to solve it . Another thing at wot on my billet fpr where should my idle be at wot cause my idle at with no pedal is at 41 but my wot is at 50 psi? where should it be at.
Old Jul 25, 2003 | 11:12 AM
Sephro's Avatar
Default Re: slight running problem (preluder)
What the hell are you saying? Did you proofread this? It makes no sense
Old Jul 25, 2003 | 11:23 AM
preluder's Avatar
Default Re: slight running problem (Sephro)
okay you know after you let the car idle and warm itself up. Well i let the car get to 1000 rpm then I drive off. But the thing is when the car gets to 850 at idle where its supposed to be when your letting off,its drops down to almost 150rpms and it feels like im about to conk out and stall. I dont what it is timing is on point and all but I dont understand why it feels like that. I have to constantly leave with the gas onto about 1500rpms so I can get a good start. Its like its starving before it pulls off. whats wrong with my car.
Old Jul 25, 2003 | 11:57 AM
Sephro's Avatar
Okay. First thing I would check would be your plugs. are they gapped right? If that's all fine then adjust the idle.
ahc'monracing
Oct 22, 2002 07:38 PM
