PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Block Oil Control Orifice Removal Single-Cam vs Dual-Cam [LS VTEC]
  2. Opinions needed. Camshaft recomendation for Stock block B18C1 daily driver
  3. WTB B SERIES HEADER
  4. Troubleshooting: CRX D16A9 cam sensor. Does PR4 support such a sensor?
  5. Team Loyalty has a question regarding a B20VTEC -Read carefully.
  6. Is it possible for GSR head to be used on a B16A2 block? Yes, easily
  7. B18C1 build. So do I use P72, or P73 usdm pistons for it?
  8. Should I bother with these JUN cams I have laying around?
  9. B16A Head Work, simple build, what to go for?
  10. b18b1 Crower 403s using a JDM B16 tranny w/LSD. Good idea or no?
  11. Woundering about skunk2 vtec solenoid
  12. Knowledge and Information
  13. Skunk 2 VTEC Solenoid question
  14. Gsr skunk 2 intake manifold installation assistance.
  15. Header fitment
  16. Bad leakdown test, scratched cylinder walls
  17. Knock sensor b20 to aux radio
  18. Ryan-EM2's B18C1 performance upgrades: What's the proper direction to go?
  19. PTO piston and and bearing bridge?
  20. Is it worth it to put a Gsr crank and rods in a LS? Is there a benefit?
  21. Ignition map changes on a B20 11.0:1 CR build. Are they necessary in my case?
  22. What is the optimal injector Duty cycle for oem 240cc injectors?
  23. B18C ITR SK2 stg2 Tuner Cams, Piston Advice
  24. 92egTN's JDM D15B VTEC project build
  25. spAdam's B20Z Crower 403 build - Ready to Experiment with E85!
  26. Motor overheat ( mixing coolant with oil)
  27. What would my compression be with a stock p72/B20b combo w/ 2-layer HG?
  28. Accordian47's Dream H22A4 All-Motor Build List- whatdoyathink so far?
  29. Need an alternative of a D16Z6...
  30. 91 Civic 3dr Hatchback Si, 1.6L (D16A6) Engine swap compatibility
  31. LotusElise's B-series 81x77.4 Engine build theories: Are they sound?
  32. B20V shavings
  33. d16y8 down on power
  34. 1987 honda civic 3 barrel carb vs weber 32/36
  35. Stock B20 motor most fuel efficient at around 3-4k rpm?
  36. Question on port matching, too much?
  37. B20 VTEC improvements?
  38. Maras78 is looking for power improvements for the B20/VTEC. Ideas?
  39. H22a starter? Need info quick!
  40. Changing the head gasket on a stock B16A2. What gasket to choose?
  41. H22a/H22a4/H22a-Euro R Cam Cap Bolts
  42. Can a Leak in fuel system cause no start?
  43. B16a simple catch can set up HELP
  44. Feels like you guys are my last hope B20Vtec
  45. Yet another "help im blowing smoke at high rpm" thread
  46. Humming noise from around the intake when car is turned off
  47. CyborgGT's H22A NA Build
  48. Brian crower stage 3 cams and valve train
  49. Block guards
  50. Greddy supreme sp exhaust civic 92-95?
  51. High compression B16 NA Bogging down feels sluggish
  52. Gsr won’t idle by itself help!
  53. Fuel Trim help
  54. Necron's High Compression B16A NA progress build thread.
  55. j30a4 engine question. Quest for 350hp w/o turbo .. Possible?
  56. Starting a basic B20vtec.build questions and input thread*
  57. Built gsr with high compression positions ignition timing help
  58. Fumey(smokey) exhaust and overflowing coolant
  59. B-series All motor help
  60. fuel pressure not stable issue
  61. Can someone confirm that these are CTR camshafts?
  62. Looking for more mid range on B18C-R
  63. K-Series Retainers on B-Series
  64. What is the Highest redline a K24/20 can safely handle?
  65. Car not started in years. What to do?
  66. This B16a small Vtec or Big Vtec
  67. Piston ring end gap problem, really need help !!
  68. Is it possible to get more all-motor horsepower with what I have?
  69. Things that improve overall torque output in a naturally aspirated engine. Chime in!
  70. Troubleshooting: 98 accord 2.3 VTEC - Starting issues after multiple part replacement
  71. Cams for "daily" driving
  72. What are the optimal size diameters for header and exhaust on a 225whp B20VTEC??
  73. B16a2 with ITR Camshafts vs. Standard B16A2 Camshaft. Inconsistent power changes
  74. Considering catch-can for track car. Suggestions?
  75. B18B1 Cylinder Heads-- Moar Power
  76. Troubleshooting : B20vtec turns over then dies
  77. Ngcsh530's proposed D16z6 power build - Initial questions
  78. NPR piston ring problem
  79. Fuel consumption on ~300hp K-series builds?
  80. What are the differences between the B20B blocks outside of piston compression height
  81. B16a2 idle problem. And yes I've done every fix known to man
  82. stock bottom end b20 vtec gsr head using Skunk2Pro2 cams. bad idea?
  83. Using aftermarket Rod bearings: How do you match up with OEM color codes?
  84. How does one tell the difference between Closed / open deck h22a?
  85. Gathering info on a swap using the J35A4
  86. Product suggestions needed: Which camshafts should I try for a High compression build
  87. Product input suggestions: Brian Crower Stage 2 camshaft upgrade w/ new pistons..
  88. Troubleshooting: B18B Timing/Firing issues 2000 Integra
  89. H22 Skunk2 cams, Tuner2 vs Pro1 lift, midrange, vtec crossover Questions
  90. Differences in Camshaft weight between VTEC & non-vtec. Not new, but interesting
  91. Troubleshooting: Integra ignition misfire during acceleraton under engine load
  92. B18b1 overheating ONLY when on track.
  93. Troubleshooting valve lash issues: Brian crower stage 2 non vtec
  94. Opinions needed: K20R Euro Accord R. Should I rebuild, or should I go for a K20/K24?
  95. H22A service manual banging my head against the wall
  96. B20ZVTEC 9.6:1 compression ratio. Is it ok to install ITR camshafts?
  97. Input & suggestions needed: Cam selection for B18C1 11.2:1-11.6:1 CR
  98. Header carbon build up question
  99. B18C1 Compression calculation comparison: 12.0:1 Pro1 camshaft hopeful.
  100. 12:1 H22A Street Build has kicked off, need advice
  101. Parts Feedback: Stage 4 Skunk2 Camshaft D16y8- thoughts?
  102. Odyssey Motor Swap/Upgrade
  103. lonlely_driver4's look at a fun B16A build
  104. B16B from across the pond 207 BHP.
  105. Parts feedback: inexpensive clutch choice for lsvtec making 220hp
  106. Honda Bike Coolant - Compatible with Honda Cars?
  107. 95mm b20a crank in b20z (stroker)
  108. What "Frankenstein" B series engine combinations are there?
  109. B16B WHP W/ Good Bolt Ons? Pics Inside!
  110. Nippon CTR PCT pistons in B20v? 13.5-13.8 compression
  111. 1992 acura integra rs wont start
  112. Why no F20B love?
  113. Crankshaft Swaps
  114. Skunk2 Tuner 2 V2V Questions
  115. How much power out of a NA B16A2?
  116. Assistance Needed: Is this a D15A3 engine? If not, what is it?
  117. Engine swap Civic 2002 LX, manual tranny
  118. Valvelifts@tdc skunk2 pro2 b16?
  119. Scat 98mm crankshaft 29lbs
  120. 4piston super99 longblock K24 90x99, 67mm Kinsler, etc Dyno results
  121. Help me plan my 270-280whp K24/20.
  122. Lightweight crank = lightweight flywheel?
  123. How high can i take my b20?
  124. Whats today's B series Valve Retainer and Keeper of choice?
  125. Best camshaft crossover B series?
  126. Skunk2 stage 2 tuner. Need help.
  127. A few questions and some info about my 2000 prelude f20b build...warning...pic heavy
  128. New Member/Novice Builder Looking For Advice!
  129. ls build question
  130. B20v_ek plans a B20VTEC build. Details inside
  131. Is this a lack of changing oil, or a residue from a synthetic?
  132. B series Skunk2 Pro2 idle
  133. Is this a good setup for 230+whp?
  134. Troubleshooting: B20 vtec cams show rocker pad wear
  135. Which Oil Pump is most appropriate to run LSVTEC?
  136. Torque specs for f20b
  137. B series VTEC rocker arm pin broke off??
  138. Gebber's B16A build Question: Should I use flat-face, or dished valves?
  139. Am I going to notice 11.5:1 vs 11.0:1 IRL. (Kseries)
  140. F20b ecu in a 2000 Prelude: Will this ECU work w/ a conversion harness?
  141. Need some info, on whether this is a good set up
  142. Troubleshooting : Inconsistent VTEC engagement - where to start for diagnosis?
  143. D16Z6 bored .5mm over - which headgasket does one use?
  144. the only FRM cylinder honing option = buy new sleeves
  145. BFDTypeR's Potential build info needed for an NA ITR
  146. Suggestions needed: 82 bore pct piston B16, what head gasket to use?
  147. F20b valvetrain question
  148. K7-1Ktrevor project: All motor d series build into a 2000 Honda insight
  149. exgr's Titanium Rod Test Tech: Possible Honda applications in near future?
  150. Can a 96 gsr tb work on the old school sk2 intake manifold
  151. Touge Monster - H23A VTEC EG6 by RGHTBrainDesign
  152. Toby1900's B20vtec All Motor plans. Realisitic, or pipe-dream?
  153. EG9 tachometer is not rotating smoothly
  154. B20 head need help!!!
  155. Novice Question: can I put a k20 head on a f22a1 block? Answer: NO
  156. What is the best exaust headers for ej9? Engine d14a2
  157. What cams and intake is ideally for a plenum - Powerband with rev limit 8K B20VTEC?
  158. What is the method for converting the VTEC Solenoid for a pressure switch?
  159. Valve Guides F20C - Honda S2000
  160. H22 JUN oil pan? Does anyone have any feedback on using this equipment?
  161. Has anyone decided to configure a J35a4 in an RWD application?
  162. Any interest in a 'header" test kit for R&D purposes??!
  163. Gsr head using a b18c5 block - how common is this combination?
  164. Replacement K24A1 VTC Actuator question
  165. exgr's B18/B20 large tube header titanium header.. Sexy, ain't it?
  166. Is it recommended to use a Reman distributor if an OEM one isn't available?
  167. B20 long block. Can this engine & sleeve support high cr or high rpm?
  168. D21x's EM1 B20VTEC Progress Build
  169. Can Oil Leaks be the result of High Crankcase Oil Pressure?
  170. Going from D series to B series VTEC: what's involved? How deep is the rabbit hole?
  171. Can head/ deck Milling mess up cam degree settings??
  172. Suggestions needed: The proper IM for b18c 85x87.2 Engine w/ toda c2 cams
  173. Using both the Brake & Accelerator Simultaneously. Good idea or Bat-sh!t crazy?
  174. Coolant reservoir bottle over flowing- 92 Honda Ballade Carb'd
  175. My tuner made a video! '93 del Sol Si - JDM GSR tuning session
  176. Old school B series rebuild - FULL story - thoughts for improvements
  177. k2h with rrc manifold
  178. Suggestions needed: assistance in ID'ing aftermarket B-series camshafts
  179. IACV throttle body port on AEBS manifold not completely covered up. Will this cause p
  180. LSVTEC different sizes of stepped dowel pins?
  181. Is it possible to bore a stock ITR intake manifold out to 70mm?
  182. H22 Wiseco Piston skirt damage
  183. Cornfuzzled's Circle Track "Street Stock" build - Which J-Series to use?
  184. Which retainers for Supertech springs?
  185. Suggestions Needed: B18C compression test results are in. Any recommendation?
  186. Coil on Plug vs. Distributor All motor B series: Pros/Cons of each
  187. Opinions Needed: Buying THESE used CTR/ITR Camshafts
  188. Is there any Play in my H22 cam gears?
  189. B16b pistons with gsr head. Camshaft suggestions?
  190. Suggestions needed: what valvetrain & valves brands are recommended?
  191. DC2dan38 needs advice on using Supertech parts for his build
  192. Crower stg1 cams in a b20 vtec with p72 head -upgraded springs required?
  193. Are all OEM Cam gears the same? LSVTEC engine build plans
  194. White Smoke Sometimes at Startup
  195. LsVtec B series Advice
  196. RDX injectors -Safe to use for E85?
  197. Feedback Request: Help me decide on street/circuit Camshafts for B-series VTEC
  198. 97mm h22 3mm head gasket question
  199. Product Inquiry: OBX Stage 1 & Stage 2 camshafts for B20VTEC
  200. Any Interest in me making Quality B and D series headers - SMSP fixtures and designs?
  201. Fluidampr - jetspeedz's Personal Impressions - Review & How-to-Install write-up
  202. All Motor B16B Build.....advice
  203. Exedy Oem Clutch for mild built lsvtec
  204. 03' CR-V and Civic Engine Swap 2.4 Compatible??
  205. 14-16:1 compression possible in an h22?
  206. B18CR Valve Springs and retainers.
  207. Hand made multi layer head gasket
  208. performance headers and downpipe for gen 2 honda odyssey j35a4
  209. mtg's review & thoughts on the PLM J's Racing replica muffler
  210. I have a lengthy multi faceted question re rebuilt engine for Honda Odyssee 2005
  211. Valve ports and manifold runner covered in oil
  212. Who could identify this TB?
  213. B18C6 - After all the work, it's not making the power I think it should.
  214. b20b no vtec high comprssion
  215. K-Series Engine Camshaft Comparison Chart - Thanks to TheMidasTouch
  216. K7-1trevor's Build: Warning! Lightweight big bore CRX Non-VTEC content inside
  217. Will a OEM DC2 ITR muffler fit....
  218. Is the Civic Type R exhaust quieter.....
  219. D15 smoking at high rpm - low miles
  220. Highest compression ratio for Stock B16A
  221. Aftermarket options for intake tube couplers with a ridge like the OEM?
  222. Looking for valve train advise for 63403 crower vtak cams
  223. Fully built NA H23 260HP - valve cover venting
  224. Piston to valve contact not possible!
  225. F20b block, F22 Head, need help with H22 head swap
  226. b16 oil spraying from oil pump area
  227. F2k swapped bb1, fwd f22c1 prelude
  228. 1992 Integra died after new rotor cap plugs and wires
  229. Possibility of Fitting the D13B7 SOHC onto a D15Z6 or Z7 engine block
  230. Turbocharged or NA? Which setup suits me?
  231. H22A7 Exhaust manifold, the best OEM H series header
  232. Trouble Shooting JDM B18C running rough/ignition timing off
  233. Type R legend: True facts and specs of the H22A7
  234. Opinion/Feedback request: LSVTECy0's quest for understanding B18C5 upgrades
  235. Ideal injector spray pattern *VIDEO*
  236. Has Anyone Ran Nippon CTR/B16B Pistons With S2 Pro 3 Cams?
  237. HP bump from CR bump?
  238. cam degree -which direction makes more peak/top end?
  239. K20a injector broken disc
  240. Oil Pump Upgrade advice
  241. Mattvivsounds B18C build thread - so many options, so little direction
  242. Product inquiry: 310cc Injectors for B18C5. Is this size recommended for my goals?
  243. Best header for my set up?
  244. Suggestions request: d155spd's B-series piston for LSVTEC combination
  245. Is it true that the intake resonator only acts as a noise dampener if ..?
  246. B16---Adjustable exhaust sprocket only?
  247. Gsr cam gears and crank pulley compatible with b16 water pump with timing belt?
  248. B20B skunk2 intake manifold - Any issues w/ running no FITV?
  249. Integra H22A - Crank But No Start
  250. Suggestions request: B18C1 Daily Driven 12.0:1CR Camshaft Options
