PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 [172] 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Oil Squirters in a LS block
  2. water and oil pump ls/vtec
  3. dropping ls cams in b20... good idea?
  4. Memory Fab vs Password JDM
  5. Can you use GSR/ITR internals in a LS Block?
  6. how much power should i expect from my b16 build ?
  7. Spinning bearings on ls..
  8. How Reliable Is LS/Vtec??
  9. b18a1 12.5:1
  10. A friend's y7 dyno sheet
  11. Do I need pistons for my NA H22
  12. ACL Race Series Bearings
  13. anyone running this
  14. b16 and LS piston heights?
  15. gsr block - ls crank and rods and jdm p30 pistons - compression numbers
  16. Has anyone here actaully used the RM cam regrinds and valvetrain?
  17. *Stock CRVtec Dyno Results*......
  18. anyone blown a motor due to cam keys?
  19. Which exhaust system?
  20. how do i build up a single overhead engine?????????
  21. AEBS or Blox?
  22. Exhaust: Megaphone with reverse cone... uhhhhh...?????
  23. B16a3
  24. b16 dyno results #2 post
  25. B16 rods and ls rods
  26. buddy club spec 4 sound clip...
  27. b16a2 dyno results
  28. Where to learn about motors and what each part is used for? (help a kid out...)
  29. b18a1 all motor
  30. HMT doing All Motor A6 Budget style (56pics)
  31. LS/VTEC Block for sale... Good Deal???
  32. anyone running big cams with a p8r head?
  33. Boost vs. NA
  34. burning oil during VTEC
  35. S2k pistons in B20
  36. headers?
  37. People with bc3+ cams
  38. Question on DOHC/SOHC VTEC engine change or swap?
  39. The destruction, and reincarnation of Tbone's Cyl head version3.0 updated daily NO 56k
  40. dynapack dyno results wanted
  41. stock 81mm block vs 84mm head
  42. WHICH HELMS?
  43. MHR's Legendary All Motor Street Civic
  44. Baran Institute LS-Vtec Project
  45. Nitto 555R vs Mickey's or M&H
  46. merge collector vs. street collector?
  47. Questions for the "BIG" cam guys
  48. how to get oil pressure
  49. Compression question, which will be better for my set up???
  50. Boring out a D15b2?
  51. New GSR owner
  52. ls vtec blown
  53. 290cc gonna be enough for the f20
  54. TWM ITB's on K20 Type R Install?
  55. Official: 2005 "What should i get with my Tax check" Thread
  56. Sorry, but another mild b18c1 build.
  57. Setting Timing Belt Tension
  58. Cam switchin on a SOHC
  59. High Compression daily driver
  60. Let's talk about reshaping the combustion chamber to increase/ decreas compression - related to head
  61. Individual Throttle Bodies on D16z??? where 2 get 1?
  62. Knocking from back of motor!!
  63. Compression Test Results - my first build so im stoked!
  64. valvetrain?
  65. engine completed
  66. Edelbrock Cams PN# 4730 ... any info on these?? $408.39 a set at Summit
  67. s2000 injectors in a b-series....who has done it
  68. toda A or skunk 1's?
  69. building a b16
  70. Omni Power cams
  71. Ls-vtec build question...remove oil orifice on top of block???
  72. pinging sound?
  73. Header swap then very bad fuel economy for a 98 civic
  74. Buddy Club Stage 4 idle?
  75. Spraying high compression
  76. High compression..... what octane gas???
  77. What Spark Plugs do you all-motor racers use on B-series
  78. greddy exhaust question
  79. ITB's and all that jazz!
  80. intake and 68mm TB
  81. B18C5 All motor build up
  82. Any reviews on a HKS 4-2-1 ITR Super header?
  83. Exhaust??
  84. noisy walbro pump, is it normal?
  85. Compression question
  86. spoon throttle body????
  87. Aftermarket Piston for Eagle Rod
  88. type r camshafts
  89. LS/vtec questions
  90. Break in with open header???
  91. ARP rod bolts
  92. ITB setup questions...
  93. Accord Euro R powered EK civic
  94. PLEASE HELP ASAP. I just install my ls/vtec........clutch wont engaged!
  95. dc sports VS. vibrant header
  96. Greddy gauge problem. Please Help!
  97. Header Wrap
  98. ITR/CTR retainers on LS?
  99. jun cams
  100. Stocc k20 in a eg V.S. Built b20 in eg?????
  101. High RPM?????
  102. What do you all-motor people use as intakes and why?
  103. BCIV's or skunk pro1 for a b20/vtec
  104. Oil Question with All motor LS VTEC
  105. BC 5`s anyone?
  106. D-series Transmissions
  107. VTEC Finally
  108. JDM ITR ECU into 94GSR
  109. buddyclub 3+ cams idling issue
  110. cam seal
  111. Venom Intake Manifold on B16a2/B18c
  112. inexpensive con rods?
  113. help finding compression on a b17a
  114. VALVETRAIN QUESTION
  115. throttle body, yay or nay?
  116. Ls/Vtec Safe Rev Limit
  117. Alaniz Tech Head Work
  118. Recommend me a TACH...
  119. Lost my sheet...piston to wall clearance on CPs?
  120. B18C choice?
  121. Skunk Pro 1 vs buddy 4's on Tbones car .. Dyno's by EVANS Tunning Pa
  122. Are honda tach's off a bit?
  123. Raised Rev limit with CAMs and SPRINGS/RETAINERS
  124. Highest compression all motor (Gas)
  125. Need help with tunning toda spec a's
  126. VAFC HELP!
  127. vtec engagement 2
  128. b16 Special Swap...
  129. URGENT cam installation help
  130. b20vtec yes or no...
  131. Mugen Headgasket vs. two-layer stock headgasket
  132. JUST ORDERED BC3+ CAMS.....ADVISE
  133. B16A2 Stock IM vs. Skunk2 IM
  134. fastest allmotor on street tires
  135. OBD0 injector on OBD1 car question..
  136. Anyone know who has P30's in stock?
  137. My B16A2 build... comments needed!
  138. Average gain of tuning in cams?
  139. Bone stock ls-vtec redline
  140. removing butterflies out of gsr im
  141. how many of us here are running itb's (individual throttle bodies) + hondata? BE HONEST!
  142. Valve sizing?
  143. anyone ever bought these headers? itr replicas
  144. NEED HELP WIT MA MOTOR
  145. after market rods.
  146. Which cam for my Ls hatch
  147. LS/Vtec installed, please help...
  148. b16 all motor
  149. 50 hp naturally asperated to my 94 accord vtec
  150. Have a guess!
  151. question about motor build...
  152. help with ls/vtec
  153. tuning my car tomorrow...
  154. were to get ctr piston\rods
  155. H22 with TWM itbs
  156. Oil pressure after rebuild ?
  157. 200 whp with ls/vtec
  158. miss fire codes.. engine not miss fireing.. causes?
  159. JDM itr pistons stick out of the hole?!?!?!?
  160. Jerry built or Portflow
  161. 305 fps VTEC
  162. Can I Reuse my stock headstuds?
  163. Can my build handle nitrous??
  164. Northwest Dyno Day at Intec Racing for Seattle and surrounding areas!!!
  165. GSR Intake Modifications ???
  166. B20vtec pcv valve relocation on a VTEC valve cover
  167. How many of you are running stock rods in your B20vtec?
  168. using 1 layer OEM head gasket, which layer to use?
  169. Need Input from B series , H series experts : Has this ever been done?
  170. d16y8/d15b problem
  171. need help no compression at all!
  172. b20vtec
  173. steady rev
  174. how to tune obd0
  175. AEM EMS vs. HONDATA S200
  176. My LS/VTEC Build
  177. HELP!!!!car is throwing iac check light after swapping an ex intake manifold on my dx
  178. 175-180whp...oem internals
  179. greddy exhaust
  180. Super cooled intake air. using freon device T or F
  181. AEM V2 intake in an EG
  182. Max Hp out of a SOHC VTEC?
  183. CTR pistons in my GSR
  184. d16 build
  185. stock dual springs good?
  186. B16A brochure from Spoon Sports circa 1997 (1391x5751 pixels)
  187. B16B with Toda C's
  188. MOTOR SHOP IN CA
  189. HELP b20 vtec blowing oil filter seal. SEARCHED
  190. Pistons Rings
  191. question about zcdohc head and D series bottom end ...
  192. inlinefour crank pulley any good?
  193. CAMSHAFT GURU'S check in please...
  194. b18c-r 98spec + ls crank or b20 crank
  195. LS/VTEC back to LS......
  196. If the vtec hole doesnt lean on a gsr motor.. why does it on a lsvtec?
  197. All Natural B16A (P30) block build ?'s
  198. which valve springs and retainers with itr cams
  199. WHERE IS THE CLUTCH ADJUSTMENT?
  200. HELP! How do you check if a Block is Legit?
  201. quick question all b series vtec crank seals and oil pump o rings interchangeable
  202. B16 TRANNY REBUILD?????
  203. d15 frankenstien build
  204. Which ecu?
  205. another JERRYBUILT lsvtec
  206. BC 3+ to Blox Spec B's ????
  207. Im new to the all motor build game
  208. cams for a stock b16-- gsr or b16a
  209. Destroked b20vtec?
  210. b20 vtec wrist pin oiling
  211. What kind of bearigns were you using When you spun a bearing??????
  212. D15B2 + D16A9 Head Swap Question
  213. CAM lateral movement?
  214. difference between ls transmissiona and gsr transmission
  215. injectors
  216. help with cams!!!!
  217. b16a MORE COMPRESSION QUESTION
  218. Nippon power Pr3 pistons?
  219. tapping noise at idle
  220. very wierd bogging vtec problem | video and dyno graph inside
  221. Running IACV with ITBs...coolant lines?
  222. no heat, hot engine
  223. B Series cams Skunk2? oem?
  224. White Civic in MD w/ integra type-r motor???
  225. block guards
  226. Ugrading my fuel pump why not injectors while I'm at it?
  227. HONDA L18 Engine
  228. Jasma header
  229. d16a6 build up.. what rods???
  230. injectors for n/a setup? worth buying?
  231. Help, Can this be repaired???
  232. injectors for itb's
  233. Damaged Bisimoto Header...Wil? Bisi? Please step up.
  234. Does my machine shop suck??
  235. are skunk stage 1's worth the extra money over the ctr's
  236. type r piston question
  237. B16a2 question
  238. What do do so many choices
  239. OBX Stage 1 cams
  240. Setup Comparison...
  241. d16
  242. Skunk2 cams
  243. ALL MOTOR HELP!!!!!
  244. Any1 doin k20 swaps in the O.C.
  245. Afraid of Ti retainers...ITR?
  246. Are my Toda B's ok?
  247. Are all Valve jobs the same?
  248. ls/vtec setup, ur opinion..
  249. pistons compression?????
  250. WTH is wrong with this crvtec?
