- LSVTEC Tranny question lsd or gsr
- ITB ?
- I need help identifying the difference between B and D series exhaust flanges.
- My plans Tell me what you think
- need help on replacing a rod
- What should i get
- C series motor gurus?
- What is block Decking?
- itb size for h22
- which cat for this set up?
- h22 building head need help....
- EGTuning.com ????
- aftermarket fuel rail is it worth it for my setup?
- cleaning the bore before building
- Finally dynoed my B16A, what do u think?
- Toda cam
- Someone help me... Im just a kid!
- Toda Sports Injection Kit
- Ls and compression
- ITB's hard to tune?
- Can I Pass Smog????
- Blown Jdm ITR, New Ls/Vtec Pics & Story inside.
- Guess what I just did........
- all motor zc.
- HOw can i get ALL out of my motor?
- Cool LSVTEC Video
- H series to B series Adapter plate .....Has began.....
- Civic VX emission failure need help
- injectors
- stock b16 power.
- Deckplate timing issues....
- Degreeing Crower 403's
- anyone here use cpracing fuel injectors?
- Skunk2 IM - can it be port matched to 70mm?
- What valve spring tool do I need for b18b
- skunk 2 IM on b16 head?
- Is .020 too much?
- honing/boring Q's
- 403s vs. sK2 stage 2 cams dyno's personal comparisons??
- camshaft crazyness
- B18B rods into D16Y8
- My Blown B18C1 Pictures...
- JDM b16 sport automatic performance all motor
- GSR block problem
- plug gaps
- b16a2 motor swap in 93 civic ex with wiring question
- weight reduction, prolly a question for the "pros"
- AN-R Header for B16?
- thinner head gasket, whats the problem??
- All motor LS, please help .. fuel/CR related.
- Quick question about Skunk2 Cam Gear?
- Trying to bump up compression a little more...
- breaking down an R motor
- My d16 allmotor project!!!
- Cams in F22
- eagle rods with arp 2000 rod bolts
- Type r rods and b16a pistons...
- loose timing belt?!?
- Clutch need replacement?
- Max retard/advance on cams for h22?
- Crank Scrapers
- b16 swap with iac probs
- Finally some dyno numbers...
- 85mm b20?
- both sets of jg gears are giving me problems?
- Advice on F22 setup (internals)
- B17 Rods and 12.5:1?
- Best Intake System
- SKUNK2 manifold vs. JDM TYPE R manifold...which 1 is better overall?
- Question for Rocket. Clutch recommendation.
- Skunk 2 Stage 2 cam settings
- majoir probelm on my conversion of b16 block and gsr head
- ITB's and IACV question.
- another cam question, help please
- ls chipped ecu question need help
- how much whp can my setup produce once tuned?
- us spec b16 cams vs. jdm spec b16 cams
- Endyn Fluidamper Views/Thoughts
- bisimoto header question?
- b20vtec cam selection..??
- Flow numbers of Prelude head compared to ITR head
- Does ANYONE know anything about THESE clutches???
- Does any body think this is a good set-up?
- Rocket Field Trips to Eibach, JG, CP Pistons, and Action Clutch.
- b20 and ls question
- The end is near :(
- Anything you have to know when taking apart a motor?
- ARC Indution Box owners
- b18b questions
- Hasport can use some of your help
- bearing question
- what motor to use
- crank question
- ef-1 plugs?
- I it will run like ass but will it work
- Clutch Decision 2004.
- Stock vs Forged Pistons
- cbr 929 throttle bodies??????
- LS VTEC NEED INPUT
- Cam choice need input
- HELP ME!!!!!!!
- Need O-ring for AEM FPR!!! HELP!!!!
- What type of injectors does H22A have. 95.
- Good Micrometer
- valve clearance question please help
- Basic B18C piston install questions...
- which intake?
- Difference between the CTR vs ITR trannys
- GS-R vs ITR Intake Springs?
- DTR...BiSiMoTo header.....
- Injector sizing.
- well I promised Pics...
- Many Miles To break in Engine LSVTEC?
- ls build up
- High Compression and Aggressive Cams
- is this a fair price for lsvtec build?
- bore size B18
- a 50 cent circlips messed up my new Engine !!!!!!! over $ 8000 invested
- P30 vs P73 Cylinder Head?
- K24 internals into K20A - Block
- would msd help?
- too much air?
- NEED HELP..
- Searched to no avail! Lapping valves?
- cam timing
- Skunk2 Stg.1 cams on stock B16A???
- injector question on HIgh comp motor
- Identity Crisis : identify stock ITR head....
- Head milling/Compression ?
- My TODA Spec b cams A/F ratio with advanced timing??
- high compression LS
- reuse valve keepers?
- Detonation
- B20 questions
- set up ??
- b18c1 hp??
- How high is to high with Octane?
- ebay obdo to obd1 conversion harness?
- gsr internals in a ls block
- could valves not seated correctly cause low compression?
- How can you tell u have a B16 SIR2??
- D16a6 shortblock spinning to 8k?
- cam choices for daily driver
- Installing springs/retainers w/out pulling the head?
- Rebuilding D16A6/Z6 mini me short block
- Blown Motor need help on crank swap to another B16
- Self engagement Vtec? Newie Q?
- Cheap header = No power ?
- p72 ecu & skunk manifold
- Need some info/advice on all-motor set up
- Proper Way to flush coolant System
- My Compression Test Results, Your Opinions...
- Spoon ventuli plate. Does it work?
- Homemade itb setups
- Performance difference of P30 piston vs. P73 in b18c1?
- bumbing up the compression on a stock b16 head?
- new all motor pictures!!!!!!!!!!!!
- Dented JDM 4-1 Header (Should I fix???) Pictures
- What you think is Best Ignition Timing and Cam Setting
- breaking in a high compression motor...
- B20Z1/B16A2 hybrid engine. Search didn't help.
- Jdm Dc SS 4-1 header + ctr/itr cams or An-r standard mild steel??
- ITR intake mani and throttle body on a B16???
- What compression ratio is needed to run CTR,skunk2 STG2 and STG3 cams?
- B18C5 bottom end with wiseco 13.1 compression pistons
- what flywheel on itr all motor???????
- Metal Property Question?
- Ecu with CTR Cams
- clocking wiseco rings
- What 2.5inch mufflers do you guys use that looks good and flows well? Post pics
- all motor moped 70mph!
- E-town opening day / ALL MOTOR STREET CAR
- b20 vtec headers
- anyone using GE vtec conversion kit?
- New Question for those w/ Homemade ITB's
- PROBLEM, tranny is making hissing sound???
- Do I have the right testpipe length
- compression calculation needed HELP
- Compression test differences between Forged vs. OEM pistons
- Compression w/pr3's and stage 2 cams?
- DSM 450's for my ITB setup...will they work?
- Intake opinions please.
- what consists of a ctr motor?
- how long for piston rings to fully seat?
- ctr pistons in a ls bock, with ls head, clearance issue's
- High volume oil pumps - Where can I buy one? Do they even exist?
- Anyone fixed stripped block threads from wrong headbolt? helicoil?
- Head Bolts?
- Cheap way to bump compression?
- Overheated brakes
- need some help
- FINALLY DONE!
- LS crank, b16 block, and head.
- d series all motor
- Anyway to run DSM injectors w/out hondata/vafc/any type of tunning?
- smsp or hy-tech header on jdm itr????
- Building an LS head, Need some advice
- toda c's..comments ...numbers n set up?
- are these headers the same? prospeed/an-r
- How-to make Low-end power????
- Problems with HIGH Water Temp
- gsr work with b16a1 ecu?
- what rods and pistons for ls crank in gsr block?
- JDM B18C - PR3 piston question
- intake cam gear sliped....anything wrong?
- dyno result
- have you heard of 81.5m p73 pistons?
- spark plug *yikes*
- 200 WHP out of ITR?
- gains to expect from dc jdm4-1/carsound cat/2.5" mandrel bent piping?
- Benson's Sleeves ?
- SOHC VTEC????
- hello to the n00b
- Stock Internals for ls vtec??????
- leaning out problem
- best e.t ina four integra
- Props To ANR Header
- b16a2 and GSR- type r fuel rail same?
- Jun 3's on stock bottom end B16a2?
- Apexi PS Revolution exhaust though?
- Will this throw the crank balance off??
- first step to ITB-----IM flanges pix as requested
- B16a cams VS. GSR cams whats the big difference.
- DOHC Timing Marks
- Which cams deliver the widest powerband?
- whats thoughts on enryn products?
- Torque Damper or solid motor mounts
- Just bought ITR Outters and Portflow Inners
- JDM Itr Pistons - Part Number ???
- DTR and Toda Header
- project ls questions
- b18b worthy of some power?
- who has the fastest prelude here....
- AN-R header
- New all motor drag, near completion!
- another cam question.. i need ideas
- My Dyno results..
- read my dyno sheet.... WTF??
- Need a type r base map
- Spoon Block Brease
- good deal on ferrea valvetrain, check this out
- why do many setups use crower retainers vs. ferrea? clearance issues?
- B20 vtec Vids ??
- LS/Vtec Question
- Running open header, does it help or not
- Want to put vtec on ls
- Can I use OEM Pistons with Forged Rods???
- main bearing problems???
- Crower Econo Rods?
- builtb20vtec vs built gsr,,,how much difference?
