- cams for street/strip b18c1
- Intercooler on all motor?
- injectors?
- Where to find a B20z online?
- does r and d have a web page? (socal dyno)
- b20 ecu question
- H22 Most Hp header
- Vtec point on S2 stage 2 cams
- still satisfied all motor ls/vtec
- good rods for allmotor setup
- What Intake pipe could i use for my 72 mm TB?
- Dynoed and 1/4 time this past weekend
- anyone ever break a rod??
- can 100+ octane hurt my motor?
- VAFC Tuning Question
- Smoke coming from valve cover breather.
- Fuel pressure with rc 310injectors???
- St Corsa Cam gear *experinces needed very urgent*
- itb's and high fuel pressue?
- quaife lsd in a si tranny or a 98 itr tranny 4.7???
- Toda Spec B parial throttle isues
- considering gsr swap, but h22 not looking bad at all
- Gettin ready to break in my motor, gotta 2 quick questions...
- Skunk2: Stage 2 Int. / Stage 3 Exh.
- b20 performance
- J's intake on D15 non-vtec
- block work
- need help!!!! vtec's gone!!!!
- How much $$$ to lighten a flywheel???
- Input On 1/4 Mile Times & What To Do Next With My Setup?
- my best time in stock gsr hatchie..
- Anyone have a b18c with ITB's?
- ctr intake/gsr exhuast cam combo...does it work?
- All motor project gone bad. How bad you ask, see pics inside
- C1 motor....vtec crossover and redline...where?
- Code 13,16 after ITB swap
- Convince me to Build it LS VTEC Related
- main bearing wear
- JDM ITR slugs in GSR Motor- A few questions!
- Which intake should I get?
- Claying block
- 89mm stroke in b18c = too much sideloading for 9k+ ?
- dyno tune= pissed off(long)
- anyone running AEM fpr with AEBS i/m?
- Sleeving a block, what happens to the head?
- JDM 4-1 header?
- Good Florida Machine Shops??????
- LS/VTEC Rev Limiter
- Which cam is this??? (no pics)
- GSR and TYPE R timing belt the same?
- I need some Hondata help!
- Shes Alive... Just need to get the hondata tuned.
- where is the cheapest place you guy have found hondata or an-r gasket
- STock heaD GAsket
- GSR Head better for ls/vtec on low budget?
- NEED HELP!
- All motor TB's
- VTEC works sometimes?
- Si Piston Question
- Decisions (Skunk2 IM or JDM ITR Pistons)?
- all motor dissapointment?
- what springs can i use, when checking valve to piston clearance?
- finally tracked timed my car
- B20 Vtec highest compression on 91 octane
- Ctr pistons with Skunk2 Stage 2 Cams in a Ls/Vtec ?
- do these pistons fit? how much power?
- Anyone use Non-OEM gasket sets during your rebuild?
- definitive b16 mods
- Valve Adjustment, quick please help!!
- individual throttle bodies
- ls/vtec
- 230 whp allmotor and 230 whp turbo. why is allmotor faster?.....
- Anyone here with custom STRAIGHT! Exhaust??
- where to get a main shaft bearing for a tranny?
- Rc 310cc injectors to big????
- any uberdata peeps in so cal?
- A/F ratio tuning
- Ebay AEBS manifold real? or copy?
- exhaust question? need advice from you guys
- How reliable is a 2.0L?
- distributor problems i think
- ****Newbie to Honda Tech tons of friends on here...got sum questions****
- what to do with iat when using itb's?
- OT... for all you mechanics...SNAP ON INSIDE.--------------->
- questions about building a b20 head
- boring my b16, few details left to answer
- Chamber Volume changes from shaving head
- TODA ITB question?
- Stock LS Connecting rods or aftermarket rods?
- Skunk 2 stage 2 cams
- Best way to spend $3000 all motor?
- Weird outcome after adjusting valves on my GSR motor..
- best header for all motor LS/VTEC
- Compression ratio and octane rating
- 10.5:1 Mini-Me setup will it hold 75 shot wet system?
- Skunk2 IM Knockoff?
- Timing belts: Greddy or Toda
- JUN II cams(how to ID?)
- Opinions about RS Machine cylinder heads......
- What are your valve clearance ( lash ) settings?
- ITB throttle bores
- type r pistons?
- lost 10 hp!
- What velocity stacks to use for CBR 954RR
- SPOON CAMS, how do you tell there real?
- built motor...i guess.
- Shawn Hilliers EK K20 All Motor Swap Pictures
- what do you think of this setup?
- just a filter on intake manifold??
- chipped ecu
- Wicked Industries???
- b18c1: 275hp and 190tq, $12000, does it worth it? details inside...
- Check Engine? please help
- b20z/vtec
- skunk2 valvetrain
- HOW MUCH TORQUE ON H22 HEADS?
- p30 piston in b18b motor?
- LS/VTEC issues :(
- intake/exhaust systems... how to really gain "15 hp" from CAI
- Getting my CRX dynoed today!
- No spark...technicians I need your help
- ID number on Skunk2 Stage 1's?
- cam settings for claying motor
- just thought i'd share my #'s
- Does anyone hear know where to take a crank pulley to see if its balanced
- question on cams...please look
- Need help installing aftermarket gauges
- F22a1 cylinder wall vs forged pistons
- b20vtec motor just handed me my arse last night
- What are the differences in D series JDM vs USDM???
- Another poormans R question
- CRX Walbro Woes
- my friends dtr header
- HELP!!!!!
- I need axles!!!
- All motor LS swap
- JDM b18c wiring harness
- tryed the b series intake manifold as well on a h22
- ITB's and Throttle cable?
- Hyper Voltage?
- Hyper voltage sytems?
- Difference between JDM B18C-R and USDM B18C-R
- bearings.....? rings...? whats the best
- Pacesetter Headers for civic or crx
- Cold Air Filter
- help me decide on cams for my setup
- d16z6 with a d17a2 crankshaft
- my all motor crx need some help
- got any links ??
- Has Anyone ever bought something kms Engine Development?
- any dynoed a b16 with gsr head?
- someone help me make more power on a 98 B18C5
- Weapon R H22 header Any good???
- ITB'S, Map Sensors, TPS, Vacuum, Fuel .........Relationships
- Question for a REAL honda technician!!...
- Can you vouch for Max (MHRacing-310)?
- 183whp stock block and stock cams
- JDM ZC SOHC VTEC ? ?
- Civic Fluidyne or Integra Fluidyne
- LS trans B18c1 prob..
- b16 flow numbers?
- which spark plugs are better
- 2-Layer Headgasket for LS? Can I modify the OEM gasket?
- What do you guys think of this recently sleeved block?
- HELP, bad compression test
- skunk2 stage 2 problems
- question for VAFC users...
- umm.. what timming should i use ?
- ls-V-tec ?
- All motor injectors for OBD2??
- itr cams on stock gsr or valvetrain needed
- clacking noise in the Type R head?!
- GSR cams in B16, vtec engagement? worth it?
- All motor D16Y8...long question....you've been warned....lol
- filter on throttle body
- built ass all motor b16's
- horsepower vs. torque?
- help with all motor...i dont noe any thing non-FI
- USDM gsr swap in bay area...
- How do you get more revs???
- what cams for b16b?
- B16a vs. B18c head: Poormans R
- toda cam specs
- dyno chart of prospeed header for h22. help me post
- valve locks
- ls/vtec computer question
- JDM ITR 4-1 header modification
- japanese B-20B... Redline?
- hondata throwing codes for no reason?????????????
- ecu help need bad
- h22 stroker
- cons to runnin straight header everyday
- skunk2 vtec cam shaft (stage1) in stock motor...
- blueprinting...balance....
- Spoon ECU Vs. Mugen ECU
- b20 vtec w/ type r rods?
- Building B20/B16 head - Parts compatability questions.
- JDM B18C and CTR crank pulley??? Which alt. belt?
- header for b16b!!!!!!!!!!!!!
- yet another honda idle surge problem... need help!!!
- VTEC Problems...need help
- Analyze my time slips
- Ericks Racing FPR install questions
- Adj cam gears
- TWM users-help needed, not another noob question
- How much WHP can a Mugen Twin Loop Muffler support?
- goin to get tuned tomorrow
- valve spring test version 2
- the 200whp test... can it be done?
- all motor non vtec b20. Which tranny to use?
- what is the jdm ITR header equivalent
- do i need valvespring seats?
- Over-Reved the B18c1 Loss of compression
- Need to find the website on How to LS/VTEC
- 1/4 mile time for the k20a
- best fuel management for ITBs
- K series injectors????
- H22a Type-S
- How many ppl REALLY have the J's intake??
- CTR/ITR exhaust cam pics....
- 1994 Civic CX w/ B20 (crv).. some opinions please
- should i get an oil temp gauge?
- poorman's r
- Does this seem right? (piston/valve clearance Q)
- Need help with VTEC CEL every once in a while...?
- VTEC OIL Cooler Info ....
- intakes poll
- H22a & h23
- reverse ls/vtec ls head on b16 block
- Help with my b16a2
- H22a vs. B20Vtec
- help with 1/4 mile times
- pr3?
- how much is a used itr flywheel worth?
- doing full motor buildup!! opinions on setup.
- need help with ignition
- ALLMOTOR STREET CRX PROJECT NEAR COMPLETION.
- Compression too high???
- New cam or high comp. bottom?
- comp cams roller cam v.s. skunk2 stage 2
- Action Clutch 1ks Users. How is it?
- good settings for 12.3 comp CTR cams?
- B20 VTEC valve reliefs?
- d16y7 / y8 ????
- Guru Knowledge - Name Your Mentors
- Lil Help
- b20b stock cams vs ls stock cams
- mod's w/B16 or GSR IHE?
- 13's in a GSR?
- Poormans ITR
