PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Coated engine bearing and their importance
  2. tips and ideas from all you guys on a b18b ITB's
  3. Cam Poll
  4. coil keep blowing
  5. ITR LSD in a GSR????
  6. Kinsler ITB's
  7. JDM ITR (B18c) vs USDM ITR (B18c5)
  8. How much nitrous?? if any
  9. Newbie Questions-What can you do with an intake manifold?
  10. H22/H23 BUILD HELP!!
  11. rocket racing cams
  12. B18c1 build.
  13. B20 Build
  14. P30's to raise compression
  15. ALL Motor-Usefull Gauges???
  16. H22 cam markings???
  17. GOLDENEAGLE GASKET??????
  18. what do you guys think about Buddy Club cams and valvetrain?
  19. is there any sense in using titanium rods instead of still ones?
  20. Did some work and hit the dyno
  21. wtb B20 crank
  22. Port and Polished Throttle Body Question - Searched.
  23. using ls transmission with all motor vtec?
  24. B20/vtec gasket???
  25. Velocity Stack instead of an Intake on OEM Manifold! Opinions???
  26. Skunk2 PRO1 H22 DYNO INSIDE!
  27. Skunk2 pro series
  28. H22 Header pics and specs T1R, Mugen, and stock Euro R H22A Prelude
  29. Head bolts????
  30. need help with VAFC2
  31. is my set up good for a mild build?
  32. another how can you determine if cams are skunk2 pro 1s...
  33. B18B not running right.
  34. Integra having issues please help
  35. d16 automatic gearbox on b18c4??
  36. Noob question
  37. k24/k20 question
  38. Ferrea Sodium Filled Valves
  39. Why all motor...?
  40. GSR with type r valve springs
  41. 00 B16 USDM/P72/ Bogging on Highway
  42. skunk2 pro1's or blox hsl...
  43. Cat. length to run a JDM 2.5" header on a b16?
  44. hunting help on freshly built head.
  45. who hasnt broken their Crower cams?
  46. Y.C.P. pistons?
  47. what is the bore for a sk2 pro gsr manifold ??? how much power would i benifit from a matching TB???
  48. Will I be alright installing these without cyliderwall damage?
  49. headgasket/cam gear setting?
  50. Getting tuned by Whipfactory
  51. New to Honda-Tech!
  52. Need some help with my GSR all motor plans..
  53. Help- OBD2 GSR bottom end, OBD2(was in a OBD1 car) head- need help with some of the coolant lines an
  54. Anyone remember the "Honda Hotrod" logo and shirts from back in the day?
  55. which cams would you recomment to use on my setup?
  56. blown headgasket (searched)
  57. obx or megan headers (d series)
  58. ....:Buddy Club Spec VI:....Anyone try them yet?
  59. Is there a need for a Fuel Pressure Regulator and Gauge if Using Hondata?
  60. Is my motor salvageable?
  61. over sized piston question. might sound stupid.
  62. Help! Oil + Antifreeze = not a good ls/vtec
  63. Max stroke for a b18c
  64. trying to buy blox hsl cams, can you tell if they are real hsl cams...
  65. 12.2 @ 109!!
  66. single layer head gasket
  67. AM folk...keep me focused on my project!
  68. Catalytic converter questions.. fitment
  69. oil pan gasket
  70. ls and sohc v-tec motor swap
  71. whats best for all motor build for Dart blocks.....
  72. HOW DO YOU KNOW WHAT THROTTLE BODY TO USE
  73. will an axel back muffler and piping fit from an ek hatchback onto an EG ???
  74. gsr intake manifold b16 head
  75. Which cams for my setup
  76. new dyno with cams!
  77. Q: what are the consequences when .... please read on.
  78. displacement calculator?
  79. going to disassemble d-series vtec head. what should I do
  80. ls/Vtec video at 10.500 rpms.
  81. Another B20vtec
  82. B18C1 Eagle Rod Bolts
  83. b16a Head- worn Journals, what to do, and how bad is bad? Please help. *pics included*
  84. HOW TO PRIME THE OIL PUMP ON B18C1 FOR A FRESH REBUILD.
  85. b16 pistons /compression with skunk2 stage 2 cams question
  86. ls/vtec build question......
  87. B20 BLOCK B18C1 HEAD BUDGET 2,000
  88. skunk2 cams valve lash
  89. another cam question
  90. 6AL MSD, Help.
  91. b20 vtec with b16 head... what timing belt to use?
  92. B18C or B18a LS Vtec rev to 10 grand
  93. Anyone know where i can get the same type of piping that come one ebay intakes?
  94. RPM Envy, how can I reach 11k screaming vtec B18c1 on street gas, is it possible?
  95. where to buy JDM K20 Type R?
  96. Stroker Help
  97. which springs are intake and exhaust?
  98. cam timing - exhaust cam opens xx* bbdc
  99. b20/vtec
  100. f20b itbs size?
  101. new strkoer kit questions
  102. Motor is acting a fool now - PLS READ
  103. cam gear settings..
  104. b16 compresstion
  105. which intake is best for drag racing?
  106. Phantom Grip Rocker Arm h22
  107. WILL B16 11;5;1 PISTONS WORK IN A GSR BLOCK WITH A B16 HEAD
  108. Where to buy oem pm7 pistons ?
  109. Which Fuel pump is needed?
  110. need engine work done in SoCal..what shops? *searched*
  111. Oil leak??????
  112. 12:1 compression?
  113. MFactory Gear Set, anyone using it?
  114. skunk2 stage2 cams Question????
  115. GSR with B16a tranny
  116. n/a poor mans type r?
  117. can my stock b16 intake manifold be ported to match my 70mm BBK throttle body?
  118. Anyone have any luck with using the factory airbox and maintaining power?
  119. stock gsr head bolts
  120. MAXBORE.COM
  121. vtec not kickin right
  122. B16a I/H/E..50 shot nitrous on a Ek
  123. D-series engine
  124. Estimated whp increase with CTR pistons on b16a2
  125. 2.75 vs 3.00 aem cai?
  126. resistors in the AIT
  127. LS/VTEC Question
  128. Tuning Your Air Intake Length
  129. ls block+p30's+b16 head=what cams?
  130. making power on a gsr
  131. best cam for my setup? blox b or skunk2 pro 2?
  132. WHAT ARE SOME GOOD HEADERS FOR B20 w/ GSR HEAD?
  133. header ? yes i searched to no avail
  134. Jdm Type R HEADER
  135. Mild gsr rebuild
  136. DYNO PROVEN?! WHICH INTAKE TUBE IS BEST??
  137. just got my gsr rod bolts for my h22 having problem
  138. just started my rebuilt motor...couple problems...
  139. B18b Valve Clearance Specs
  140. How Hard To Mod DC 4-2-1 Ceramic Header?
  141. Portworks Racing RBC intake manifolds
  142. Neccessary to reBORE or just a hone - severe ring leakage
  143. Bronze vlave guides or OEM
  144. LHT?????????
  145. which bearings to use with b20vtec?
  146. Skunk2 Pro Intake Manifold Question...
  147. I lookin for 200HP!!
  148. ACT or Exedy Clutch on All Motor GSR.....wat would be better???
  149. Hit up the track last night
  150. What cams do I have?? HEL:P!!
  151. B20/vtec with wet zex kit????
  152. Skunk2 Carbon Composite Intake Manifold
  153. barebone car?
  154. My gsr problems!!!
  155. When biulding your head?
  156. How to make a piston disapear, and destroy the rest of the engine as well.
  157. check engine Error code 1 or 10??
  158. H22 bored 91mm or H23crank + 89mm
  159. engine problem. HELP
  160. 93,16deg,12:1
  161. best cam?
  162. first all motor setup
  163. Question regarding Buddy Club SPEC III Camshafts #17639
  164. jdm p30 pistons in a gsr block
  165. honda b20b with p8r head
  166. AUTOMETER TEMP GAUGE ?
  167. compression test
  168. b18c1 block, how much???
  169. CTR pistons in b16 compression issues?
  170. Intake Question for NA setup
  171. B20/vtec oil leak???????
  172. ctr pistons, b16 rings okay?
  173. cleaning engine???
  174. 2.0 gsr for 2.4 h22???
  175. VictorX manifold or itb's?
  176. Buddy club cam gears torque ?
  177. b20 question?
  178. Apexi Power FC Tuning Experience
  179. uh opps i ended up with 13.03 c/r
  180. ZR header???
  181. blowing smoke
  182. B20/vtec???????????
  183. apexi i moni
  184. CNC Ported Head
  185. Anyone heard of ZR racing headers before???
  186. 220+ WHP clutch compatibility?
  187. Type R final drive identification help
  188. Most Power seen out of a NON-Vtec motor?
  189. lsvtec
  190. Should I keep my S2 S2 cams?
  191. Burner for a Crome P28
  192. Hytech or OBX
  193. j's intake vs. 3" sri magic stick
  194. jdm ctr pistons with eagle rods
  195. where to get engine hot-tanker, honed, and micro-polish in sac. CA?
  196. Piston speed and its importance
  197. My Stock Block NA H22
  198. 240cc good for 180whp?
  199. Test Pipe or High Flow Cat?
  200. anyone know if i can safely run 88mm bore on stock H22a sleeves?
  201. my problem with b18/b20 buildup
  202. b and h use the same valve spring.
  203. Variable Exhaust Geometry
  204. Milage on a semi built b16 in an EG ????
  205. How much does a tune cost?
  206. H22 Bore, Hone, or Trash? Pics!
  207. I want to build my motor! Who wants to suggest some possible setups?
  208. 12.5 CR Timing, hondata
  209. Help with my setup
  210. ITB Filter options and where to buy them???
  211. a little help or ideas?!?!?!?!?!?!
  212. 85.5 mm, what headgasket do I use?
  213. Basic B20 build....dyno results are in.
  214. **OK H-T, One Of Our Own Needs Our Help, Please Step Up To The Plate**
  215. buddy club spec 4's on a stock B series type r?
  216. 83 mm sleeve
  217. 3 inch Thermal Exhaust to big for 150whp D16?? 2 inch HKS To Small??
  218. Spitting Oil -pls give it a read
  219. ls/vtec b16 head which power steering pump bracket?
  220. BLOX HSL Competition series CAMS
  221. Would these be good pistons for d.d.?
  222. 9000rpm h22
  223. will it blow?
  224. Ice Man style intake for K series
  225. NEW SETUP
  226. Advice on building b18c1 on 92 eg??
  227. skunk2 stage 2 cams vs. procam 1
  228. ideal cai intake pipe diamiter?
  229. The Winter Long B16A build
  230. Are there any 400+ hp h22?
  231. Whats Cams Are Theses?
  232. questions about stroker kits
  233. all motor b16 questions
  234. Skunk2 S3 cams TOO Big for my setup????
  235. cams
  236. oil pump issue? help
  237. How much is a b16 hydro tranny worth?
  238. need some help with my build on my gsr head.
  239. i wanna go all motor
  240. hondata s300 / jdm itr help needed
  241. LS/VTEC 1.9L TWM ITBs - Which cams to go with?
  242. Dry sump prices??For h series
  243. skunk2 pro1+ vs Pro2+?
  244. Cams or ITM
  245. H22 performance
  246. y21 tranny question
  247. Can I swap my final drive on my Y1 trans?
  248. any a shop in the tampa bay are
  249. Is 300whp achivable from a B16A/B20B Setup
  250. help with machine shops
