Input & suggestions needed: Cam selection for B18C1 11.2:1-11.6:1 CR
Hey guys, I'm currently in the planning stages of my engine build and need a little help selecting a cam. I have a handful in mind, but am open to all suggestions. Essentially I am going to be building a Spoon-esque B18C1. Crankshaft balanced, pistons and rods balanced, and I'll be upping the compression to around 11.2-11.6 through the use of different piston and head gasket combinations, generally based around price and availability. What cams play nicely in that compression range? I don't want to over- or under-cam this motor and I'm looking for roughly 190-200 whp. I've been tossing around the idea of either S2 tuner 1s, tuner 2s, and pro 1s, but have found quite a bit of conflicting information. Any advice is greatly appreciated!!
re: Input & suggestions needed: Cam selection for B18C1
Most will tell you to go look at the all motor dyno results and do some searching as this is a come build that 3 people just asked about in the last week. My advise to you pro 1 for more low end or the tuner 2 not the 1's
broketuner-Sol_Si
02-02-2006 08:50 PM
1997GS-R
11-08-2005 11:58 AM
