PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 [150] 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. B16 Swap in DA Questions...
  2. HEAD THREAD PROBLEM
  3. 200hp car - FWD vs AWD
  4. Question: where is a reputable shop to have transmission service done.
  5. homemade itbs?
  6. busa itb tps wiring?
  7. For all the All motor and Mugen maniacs....
  8. Where to get jun 3 cams?
  9. Jun Type4 vs Toda B dyno results
  10. Skunk2 stg 2 cams-typical power output?
  11. Stock GSR motor...I want cams and need help please
  12. head not getting oil pressure???????????
  13. high compression b16 all motor timing
  14. Pics of El_Capitan's build!!?? ....
  15. lsvtec which arp head studs?
  16. ls/v q?
  17. b16 head question????
  18. torque specs
  19. cp sensor timing problem
  20. 181whp and still dog slow?
  21. auto to manual swap
  22. Eagle rod bearing size
  23. PUTTING NATURAL GAS PISTONS IN D16Z6
  24. b18c5 Block with b16 head Do I use Dowel Pins??
  25. Motor Cuts Out at High RPM.... Any Ideas??
  26. itb fotos and opinions
  27. machine shop to do spirolocking
  28. Question: Will Car Pass CA Smog Emissions with Upgraded Cams? (skunk2, toda, jun, RM, etc)
  29. b16 vtech info
  30. obx cams
  31. skunk stage2/jun 3 specks
  32. ls/v-tech
  33. help plz i tryed everything
  34. Anyone run Thermal catback on B18C w/no cat?
  35. 1 layer h/g to raise c:r???
  36. ITB's for a H22a
  37. Does RMF Street Header Fit EF 88-91 W/Traction Bars?
  38. having trouble getting LS/Vtec to idle properly, <need heal fast!!>
  39. B16 All motor
  40. B20 nonvtec crower 404 dyno
  41. B16 head milling?
  42. whats max B18B horsepower?
  43. engine building in progress...any suggestions???
  44. Bottom End Building
  45. ecu reference book number
  46. Jdm<>USDM
  47. built f22
  48. Type of fuel
  49. anyone sent there head out for port & polish
  50. How DO I fix A Warped Cylinder Head ??
  51. compression test with no power?
  52. CTR pistons, stock LS cams (LS MOTOR) this ok ?
  53. do i need a new intake manifold??
  54. Throttle Body Injection
  55. Info on ITB's
  56. thinking bout going bigger manifold wat do u think
  57. Has anyone used omni cluth master cylinder?
  58. Buddy Club spec IV or Crower 402-2
  59. Stock Ls Rods over Eagle rods
  60. how do i put on a vtec head on a ls
  61. does a throttle body do all that much?
  62. ? about my exhaust set up...
  63. Ctr pistons and Jun 3's now running to rich? what else to change before dyno?
  64. spun a rod bearing??? HELP!!
  65. <<**another HOOKUPS street car 217.6 hp 154.3 tq EK pump gas!!**>>
  66. vtec solenoid
  67. ***** Sea Foam PROBLEM, NEED HELP!!! *****
  68. do i need the walbro?
  69. compression when using skunk2 stage 2
  70. Dart B20 block...come with vtec or its non-vtec???
  71. SKUNK2 springs/retainers with skunk2Pro 1's?
  72. intake or exhaust upgrade?
  73. Piston Install
  74. How much power do you think this setup would put out?
  75. GSR build displacement and CR questions?!??
  76. B20-Vtec PCV Valve?
  77. Is "mr. gasket" quality or crap?
  78. i'm looking for a 92-95 civic 4 door wrecked in anyway with a title
  79. Is 70mm TB/Manifold too big for na b16?
  80. 96spec jdm integra type r motor vs 98spec jdm integra type r motor
  81. will 91 octane work with 11.6-1 compression? how can i make it work? mix gas?
  82. Vtec cross over point?
  83. Vtec wont work...already searched. help plz...
  84. Hondata tuner?
  85. M22's in a B16A pulling hard!
  86. need help identifing these crank...<pics inside>>
  87. Need motor help!, high compression b18a won't stop smoking
  88. Need motor help!, high compression b18a won't stop smoking
  89. Blue smoke after installing ITBs
  90. ek9 cat flow well ?
  91. Considering all motor...
  92. obd1 to obd0
  93. What are my Rev limits (best estimate)
  94. need help choosing cam setup!
  95. Possible to reuse hg?
  96. best pistons and head for build up. d-series
  97. Oil pressure before vtec and after?
  98. crower stage 2 cams
  99. Backyard Exhaust for B16A
  100. GSR all motor set up aiming for 250whp....
  101. CTR Pistons with GSR Head(92 Octane)?????
  102. New crank pulley?
  103. allmotor LSvtec power? hear me out!
  104. Anybody heard anything about....
  105. WTF is up wit my traanny??
  106. engine swapping on acura legend?
  107. *Need help with CR*????
  108. thermal exhaust question
  109. HELP H22A ALLMOTOR?
  110. headers help
  111. Compression at 60 psi across, Cam Timing?
  112. painting a header?
  113. what would u do.
  114. oversize piston question
  115. bc5 cam spec card ?
  116. Just Got My SMSP Header (Pics)
  117. Ls/Vtec safe revving?
  118. D16 cam choices... please help me decide!!!!!!!!
  119. Why All Motor???
  120. where to find chep sleeves
  121. what is better?
  122. Cracked Exhaust manifold
  123. what horsepower and tq do you think i will get with this build
  124. What to do......
  125. F! the ITBS I wanna put a carb. on my car!!!!!
  126. bc3 cams with RM gen 2 valvetrain
  127. Toda Oil Pump Gear - 80 or 84mm? (searched)
  128. A/F gauge?
  129. race gas.. is it worth it?
  130. Will a B16 bolt onto....
  131. wats the best way to know
  132. how can i tell the different..
  133. engine builder in ma/ct?
  134. quick question
  135. Link to LS vs B16 dyno....
  136. what piston ring size for CTR pistons/LS rods??
  137. B16 Milled Head and Skunk2 Stage2, lot of questions
  138. 300 out of an LS/Vtec
  139. b20vtek
  140. I WANT TO KNOW IF JACKSON RACING SCHARGER
  141. d15b1 mini me swap problems
  142. difference bet. weisco, cp, and arias
  143. Your thoughts on these headers??
  144. Need Advice on Itr build
  145. Whats a good cam for my setup
  146. Idle Sticking PLEASE HELP
  147. Bogging / running lean at wot with ctr intake cam
  148. Clutch any good?
  149. Anyone in here used to be a FI guy?...
  150. Future engine swap... best choice???
  151. what tranny do i have?
  152. Buddy club spec 3+
  153. N/A Newbie Cam Question (Searched)
  154. calling all ls/v with ctr pistons hp#'s <<<<<<<,
  155. need help on BC 3+ cams
  156. TrackSpeedRacing ITR 209hp ...dyno
  157. $4000 to spend on all motor A6
  158. HEad package for us ITR motor. what is best
  159. ** NEED INPUT ** ITR or Omni Valves? TODA Valve Springs w/ what retainers?
  160. newbie question since search is down
  161. Upgrade Exhaust?
  162. carb itb
  163. Does anyone know about the stage 1 Skunk2 Pro series Cam
  164. heater cable replacement
  165. Help me decide...Transmission wise
  166. Skunk2 Pro 1's....N E one know a place with a decent price on them?
  167. ITB tuning - map problem...need help from the pros
  168. Gas mileage buildups? Chime in!
  169. what is the best diameter for the exhaust pipe on a b16a2 2 inches, 2.25 or 2.5
  170. ALL MOTOR HEADS Is it possible
  171. h22a vs. b18c
  172. ENDYN rollerwave psiton & EAGLE rods 4/sale...
  173. Ek-CoolGuy's 1.8L GSR Project
  174. Best carb exempt header?
  175. b16 head cc's
  176. Spark Plug Wires Suspect or Something Else????
  177. Exhaust for B16B
  178. what setup will make the most HP
  179. vtec head on 94 si h23???
  180. my engine bay M22 content
  181. piston sizes on standard sleeves b18c6 itr
  182. valvetrain upgrade?
  183. Anyone have experience with JDM style dual carbs?
  184. ls/vtec sputtering vary bad pls help
  185. Goin rate of k24 Element, CR-V, or Accord motors?
  186. Hondata S300 Basemap and initial startup settings
  187. new motor problems!
  188. Tuner needed in New England area!!!!
  189. ctr exhaust cam?
  190. --------> DOWEL PINS <----------
  191. Building All Motor B-series
  192. Looking for a cheap hybrid motor swap? B18A/B longblocks and tranny for $395!
  193. For those of you with an inherantly unstable idle
  194. itr retainers/valves/valvesprings in b16a2 head?
  195. Aiming for High 11's, Am I going towards the right direction w/ my B-series build?
  196. LSVTEC > B20VTEC, need build advice from experienced b20 builders
  197. Does anyone have the specs for the Skunk2 Pro2+ cams?
  198. Are Type R & GS-R oil pumps the same? Yes they are!
  199. help me with my all motor build
  200. is it necessary to replace water pump every timingbelt renewal?
  201. crx si W b18 jdm gsr
  202. Cam Gear adjustment help
  203. ZC Motor cuts off, HELP!
  204. Weird part throtle dead spot
  205. B18b vs. b20z
  206. Cam question
  207. LS block, GSR crank & rods, ITR pistons, PR3 head....reliability questions
  208. Inline fuel pump helps NA?????
  209. possibly buying an ls/vtec hatch
  210. Bore and stroke?
  211. D16a6 vs D16y7 head flow
  212. Sound clip. Buddy Club Spev 4's in B18C.
  213. overall timing advancing????
  214. About to buy a USED but "Built" GSR Head...what to look for? precautions? etc.?
  215. Cheapest source for a K20A JDM-R Motor?
  216. to Micro polish or not to Micro polish?
  217. the best honda engine
  218. LS/Vtec hesitation??? p72 ecu??? ignorance is not bliss.
  219. question about itb's
  220. dyno shift points
  221. what kind of numbers am i looking at
  222. B18c1 rebuild options (which crank, pistons, rods, etc)
  223. Stumped...car won't start
  224. crower 402 regular and 402-a
  225. b16 w toda vtec killer cams
  226. port and polish skunk2 IM ?
  227. black poo in the headers and IM
  228. boring out skunk2 mani ?'s
  229. No clue whats going on!!
  230. Turn open differential w/ finger??
  231. 300whp H23
  232. Skunk 2 Stage 2 cams and injectors
  233. Mustang t-body meet H22......
  234. I Need Guidance LS VTEC or B20 VTEC
  235. Port & polish
  236. quick question do p30 pistons fit ls crank and rods without mod?
  237. gsr cranck question
  238. Spoon Piston Kit Question
  239. B16 Rods bearings in LS rods..... Look!
  240. what cams and valvetrain 12 5 1?
  241. K-series: K24A4 simple build
  242. <<<< ALL MOTOR ENGINE>>>>>
  243. vtec sputter
  244. what are the stock b16 and b18 cam timings
  245. Disaster averted
  246. ls stock fuel pump urgent!!!
  247. Tapping from Spark Plugs on plug wires???
  248. GSR head on a B16 block..
  249. anyone have a built allmotor sohc vtec?
  250. stock gsr motor with Jun program
