PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 [194] 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Hondata Base Map...
  2. Stroked GSR?
  3. ctr pistons in lsvtec...I need the truth!
  4. Is 6 hrs reasonable for an H22 cam swap?
  5. Kamikaze Header???
  6. Northeast H-T Dyno Day
  7. CGP99Coupe
  8. Spark Plug gap, high CR, displacement...
  9. DX motor is tweeking..
  10. can i use LS Intgera rods & pistons in my b20b with b16a2 head?
  11. whats the most reliable way of increasing discplacement?
  12. b16a second gen Q
  13. PR3 1.6 Litre ECU on B18C 2.0 Litre Engine
  14. 85mm 13.5:1 be OK? for Daily Driving?
  15. b16 make it a 2.0
  16. a little advice on valvetrains
  17. about to go INSANE ....please help..anybody
  18. NEED HELP TO GET MORE POWER
  19. what kind of hp should i be putting down (tuned)
  20. Omni Power valve springs
  21. skunk2 stage 1 in 99jdm itr motor
  22. Recommended build of B18c out of a 99 GSR??? Suggestions for new member???
  23. new clutch..
  24. post ls allmotor setup
  25. GSR rods and TYPE R ???
  26. boring skunk2im tb opening?how big?
  27. Dead piston
  28. Pistons for LS?
  29. Looking for a lil more power out of the b18c
  30. Where to tune? Im in Columbus Ohio Hondata
  31. Compression Ratio on pump gas
  32. how many are running stock block lsvtec???
  33. what must be machined to put ctr pistons in a b16
  34. What kind of injectors/mods should I get to compliment my setup?
  35. cbr it filtering
  36. b16 finally going in
  37. b16 nippon racing ????
  38. Optimal revs range for Crower Cams
  39. 278 transmission trouble code
  40. b20vtec or type r ? dilema
  41. checking timing w/ ctr n1 pulley
  42. timesert installation (thanks DonF!)
  43. whats more reliable? all motor, turbo, supercharged?
  44. Sleeves
  45. Can anyone help me?
  46. going to the darkside, lsvtec build, need opinions..
  47. Skunk2 high comp. valves
  48. better gas mileage w/ preformance parts?
  49. What cams should I get?
  50. Need Help with cam gear settings...
  51. oiling issues after mild h22a4 n/a build
  52. mag filter can save your motor?!
  53. Is it worth it?
  54. looking into building ls/vtec
  55. Engine Swap (d15 to b16) Won't turn over
  56. GSR head with ITR intake cam
  57. do you absolutly NEED to resurface flywheel?
  58. Header Help Please!!
  59. High compression with stock head/cams?
  60. GX pistons for a D15B7 ?
  61. The Beast GX20 by Mr. Gasket B-Series 270hp Swap!
  62. VAFC or Fuel pressure regulator?
  63. GSR build, a couple of questions.
  64. CRV/VTEC daily driver is it reliable
  65. Anyone using Valvoline VR1 in their engines?
  66. d16z6 into ek civic
  67. 11.3cr with fpr
  68. I got idling problems need help
  69. whats the most nitrous anyone has sprayed on thier gsr motor?
  70. b16 cam
  71. Ohio Engine Shop
  72. rsx type s throttle body question
  73. ARP rod and head bolts?
  74. All OBD1 Injectors are 240cc ?
  75. Durability question in B18C1
  76. H22 Hatch NO VTEC NOW
  77. VAFC wiring diagram for NSX
  78. Anyone running ITR valvetrain with 12mm cams??
  79. Scat Cranks
  80. Can anyone send me the kenji .bin?
  81. SHOW ME PICS OF COMPLETE GSR SHORT BLOCKS
  82. Fitted Power FC, now got flickering dash light...
  83. HELP: strange noise after highway brawl with an 2.8L Audi A4
  84. Cam comparison
  85. Need help identifing clutch (pic included)
  86. Valve job on D16z6
  87. should i put type r cams in a gsr
  88. Need help with jdm 4.7 final
  89. ls/vtec questions
  90. H22 Question on ignition systems
  91. lsvtec back to gsr???
  92. LSVTEC problems
  93. question on INtakes for h22a
  94. b16 in eg... which ECU?
  95. Would ITBs fit in a K20A EG ?
  96. Head packages?
  97. High revving B20...
  98. Ghetto-Modding: Enlarging header collector
  99. finally got my block & head...
  100. B20VTEC ?
  101. can a b series lsd be swaped into a d series cable tranny? (89 si)
  102. H22 Crank Pulley & Oil Pump Gear Tech ?'s
  103. WANTED: Tuner in Twin Cities
  104. H22 Civic Finished
  105. Starting b20 build, need some advice, tips
  106. obx lsd? is this too good to be true?
  107. Auto B16a head VS manual B16a head
  108. Jun 4 clearance #'s inside
  109. Info on B16A1 / A2
  110. What Are The Best Cams For A B16 N/A Build.....
  111. Question.....
  112. What are retainers ?
  113. ITB and ecu gurus please come in
  114. good head porters
  115. Car Bogs out real bad, need help!
  116. Skunk II stage 2 cams and compression?
  117. Built b16 dyno disaster!
  118. Consequenses of New SL Rated Oils
  119. 2 step vtec ???
  120. New Project begins...(56k take a nap)
  121. Which 2004 Honda Automobile Engines don't use Roller Rockers
  122. Tuning Increases?!
  123. JUN cam users...how many miles do you have?
  124. Which valves springs to use???
  125. lsvtec power increase
  126. Need a Hondata tuner in SW Texas, South NewMexico Area
  127. h22a type s cams
  128. which cam for b16a3 head and 11.3 cr gsr bottom?
  129. Skunk2 IM on GSR
  130. compression numbers needed
  131. -----------------> K24 EG CUSTOM HEADER PICS <--------------------
  132. yet another burnin oil b18c1
  133. CTR intake camshaft, upgrade?
  134. GREDDY E-MANAGE WILL WORK ON OBDO ECU???
  135. valve clearance for b16 w/ big cams and pretty good compression.... searched
  136. TUNING A B16A2 ALL MOTOR WITH GREDDY E-MANAGE???
  137. short vid
  138. Removing the bronze rivet tab things on headgasket for LS/VTEC...why
  139. omni power valves
  140. Hytech header clearance in an ej???
  141. My All Motor Set Up
  142. Skunk 2 ecu for b18c1?
  143. porting and fuel indents
  144. air blowing out of valve cover if you take oil fill cap off......92 accord 4 cyl.
  145. My all motor setup is finally going in...
  146. my all mota build..fellow h-t peeps let me know whatchu think (56k beware)
  147. b20 set up help me out
  148. exhuast question?????
  149. p72 vs pr3 head NEW POINT OF DISCUSSION
  150. ls/vtec timing covers
  151. BEAST motor price reduced!
  152. ecu question help???
  153. Crower Stroker Kit
  154. k20 eg vs. fully built b18c1 eg
  155. d15b8 buildup??
  156. Help -> Trying to get over 175hp
  157. Anyone with Cylinder wall pics
  158. just got my b16 w/LSD.... HOW DO I KNOW ITS REALLY LSD
  159. ls head with vtec valve train??
  160. Where do I find RLZ and Rocket Motorsports products?
  161. jdm b16, why 4-1 header?
  162. help me determine my compression ratio
  163. Intake Manifolds
  164. 88 Accord keeps stalling out???
  165. Do you think my LMA's a bad?
  166. ANYONE WHO HAS BEEN SCAMMED BY JASON FAMA READ THIS!
  167. cams for 11.5 cp on b16b
  168. building an all motor h22 got ??
  169. FINALLY got it back together
  170. new engine for old
  171. B16 Crank in JDM B18C-R? Experts needed pls.....
  172. apexi vafc h22?
  173. Peak Cams??
  174. Motor issues!!!
  175. looking to see if i'll have any problems putting these parts together gsr head, b16a2 block, obdo st
  176. ls/vtec clearance
  177. sohc help!!!?
  178. b16b head vs. b16a head
  179. chipped obd1 or hondata?
  180. best cams for an ls non vtec
  181. LS Motor
  182. which motor would be cheaper to build up and better???
  183. I GOT A FREE CYLINDER BUT IT DIDN'T COME WITH THE CAM CAPS.
  184. most reliable cams that make power on an H22A
  185. 220hp h22?
  186. fresh build and car won't accelerate past 3500 rpm's
  187. head porting...what works and what doesnt?
  188. idle problem.
  189. h22a ecu?
  190. any input on this?
  191. What do you guys think about light weight flywheels ?
  192. completely stock gsr question
  193. good tranny setup for a b16?
  194. need help on injector sizing.
  195. Another AN-R thread. vids inside
  196. cam cap studs??? good or bad idea??
  197. B16A2 ALL MOTOR WITH GREDDY E-MANAGE???
  198. e-manage or itr cams???? on b16a2
  199. ECU setup? mugen chip experience?
  200. Couple of LS/vtec questions...
  201. All motor b18a, block progress!
  202. need advice on what to decide
  203. - need some help please -
  204. little header test
  205. na d15b vtec
  206. My civic hb with the ls swap
  207. How much would a valve spring installation cost?
  208. For the fans of B-series tuning - Check this out!
  209. DYNO or Wideband for b16a with toda b cams?? Look at the track times -Please Help!!
  210. New setup finished
  211. F20C
  212. what else will i need for my H22 engine swap?
  213. GSR block with LS crank?
  214. reving question
  215. H22 THROTTLE ON B16A INTAKE MANIFOLD???
  216. OBX cams
  217. ARP Stockist Required!
  218. Wanted: installation on skunk2 stage 1 into itr motor. will pay for labor in solcali
  219. B16 w/LS crank questions
  220. Radiator leak, overheat and now hesitation....
  221. All-Motor Setup...
  222. Del Sol D15 (16vavle) non-VTECH (engine mods wanted)
  223. b20 vtec anyone
  224. need help on ITB fabrication
  225. all o.e. part BEASTS
  226. Those who have CTR slugs in B18a's come in...Compression question (not CR)
  227. Piston to deck height ????
  228. pic by request and a question.
  229. What kind of #'s do you all mkae? is this possible?
  230. what kind of 3's do na car make? is this possible?
  231. K24 / 20 Dyno chart Dynojet 5thgenjon car
  232. What oil?
  233. New Dyno Numbers, so getting close to 200
  234. who does the best headwork for NON VTEC motors?
  235. Cam Suggestions
  236. I took the car to the track 98 EK with CTR Swap
  237. gsr block with gsr head or b16head? which one better?
  238. anyone ever seen this thing???
  239. building a b18a.....
  240. Wut do i need to Change to put a Gsr in a crx????
  241. need ITB help fast
  242. 82mm b16 help!!! need opinion from tuners
  243. Which cams for B18C1 ?
  244. CTR cams on GSR valvetrain....
  245. 8k rev limiter on d16z6 good? or bad?
  246. have hesutation after warming up and check light
  247. All Motor Knocking noise help me..
  248. HELP!!! rpm/spark PROBLEM
  249. If you were in my shoes...
  250. Problems with my Cylinder fouling - LSVTEC, Stumped!
